Old 01-16-2013, 02:26 AM   #1
badpeanut
Not a bad nut after all..
badpeanut's Avatar
How to Adjust Factory Tachometer?
I picked up a factory tach from a big truck and just finished installing it and a reproduction vacuum gauge in my Blazer. Unfortunately the tach feels like it reads a few hundred RPM high. I have HEI and a late 1970's Camaro tach filter. I'm going to temporarily hang an aftermarket tach under the dash for comparison. I read in other posts about the calibration screw on the backside of the factory tachs:
1) Can I reach this screw without removing the gauge cluster (is the circuit board in the way, do I need Ethiopian arms, etc)?
2) Is this screw a flat head or Philips head?
The tach currently sits nicely at zero RPM with the ignition off.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 01-20-2013, 08:03 PM   #2
badpeanut
badpeanut's Avatar
Re: How to Adjust Factory Tachometer?
I hooked up this old (50+ years old according to Snap-on tech help)tach/dwell meter first to my other truck with a new Sun tach on the column. Difference was a consistent 200rpm across the board.
Next I hooked it up to my Blazer with the factory tach; the factory tach is 500-700rpm low and the difference gets even greater with rpm.
'70 GMC LWB trailer
Old 01-21-2013, 01:28 PM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
If you have a 6 cylinder engine and a v8 tach it will read 25% lower at all rpms.
If you have a v8 with a 6 cylinder tach it will read 33% higher at all rpms.
I may have my % off, its been a while since math class.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
