Old 06-10-2003, 04:37 PM   #1
dubie
dubie's Avatar
oil pump pickup tube
Ok, I bought a new oil pump for my 350 rebuild project and it came without a pickup tube on it. I ordered that separetly and it arrived today. Does this have to be installed in a press? and tips?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-10-2003, 04:41 PM   #2
Professor
Pick up tube
Figure out exactly where you want it -- the orientation or height, that is. Set the pump on a solid surface, get the tube started, then use an open-end wrench above the collar and drive it in with a hammer by tapping on the flat part of the wrench. I belive on small blocks it is a 5/8 wrench. Welding a very short bead (just a tack, really) will hold it in place if you're worried about it moving or falling off.
Professor is offline   Reply With Quote
Old 06-10-2003, 05:10 PM   #3
dubie
dubie's Avatar
thanks for the tip
Old 06-10-2003, 05:21 PM   #4
ddsmith
Glowing since 1978
ddsmith's Avatar
Just be cafeful on the heat build up if welding a tack because the spring if heated will lose it's tension and constantly bypass the filter. You could remove the spring, weld the tube in place, let it cool, and then reassemble.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 06-10-2003, 08:44 PM   #5
sbc350gearhead
sbc350gearhead's Avatar
They also make a clamp that goes on the pickup and then bolts to the oil pump, to keep the pickup in place. Jeg's and summit sell them.
sbc350gearhead is offline   Reply With Quote
