01-17-2013, 10:18 PM | #1 |
4x4 two 2 wheel drive????
How hard is it to convert a 4 wheel drive to a 2 wheel drive? What to use to do so? Good idea or just keep looking for a 2 wheel drive?
OLDIRONRACING |
01-18-2013, 12:17 AM | #2 |
Re: 4x4 two 2 wheel drive????
OK, please understand I'm not bashing here - I'm truly curious. I know there are a lot of guys who like the 2wd, but why? Why take a 4wd and make it a 2wd? The 4wd can do a whole lot more.
01-18-2013, 12:33 AM | #3 |
Not bashing either. I just don't understand why you would convert a 4wd into 2wd.
01-18-2013, 01:24 AM | #4 |
Different strokes for different folks. I have no interest in going off road, therefore a 4wd makes no sense for me. I was gonna buy a 4wd and convert it before I found my factory 2wd.
OldIron : it is actually quite simple. There are a few conversion threads in the build section. If I can find one I'll post a link for you. Posted via Mobile Device
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
01-18-2013, 09:00 AM | #5 | |
There seams to be a lot more of the 4x4 out there. Posted via Mobile Device
OLDIRONRACING |
01-18-2013, 01:31 AM | #6 |
SKINNY TIRES RULE!
I love a nice 2wd - converted or factory. I've thought about converting mine more than once.
Here's a great article on the conversion - http://www.sporttruck.com/techarticl...wd_conversion/
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
01-18-2013, 01:50 AM | #7 |
It should be pretty easy I would think, just take the front drive shaft out.....tools wise, I'm sure a wrench would do the job.
I think it would probably be easiest to buy a junk 2wd truck and swap everything you need from it. |
01-18-2013, 10:44 AM | #8 |
Just a nother gear head
Its not to hard at all. find a 2wd truck and swap out the parts. you will need to drill a few holes in the frame for the front cross memeber and maybe a few in the rear for cross members and such. also will have to fab upper spring mounts as the frames are different. then swap trans out.
But why do it? becuase there is alot more 4wd's then 2wd's and a lowerd 2wd looks sweet. plus if your not into 4x4 why have something you dont like, convert it. its all in what you like.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
01-19-2013, 07:42 AM | #9 |
I did it with my 71. and I have a build thread going too. Even though i haven't had time to work on the blazer in a long time. But you can see how I ended up going about it. I 4-wheeled the snot outa my blazer in the day but time and money, ect. put a damper on things. A good blazer tub is hard to find around here without breaking the bank. And I didn't need 2 4x4's but wanted a 2wd gitaround rig. Well my tub was pretty dang good shape vs. most others out here. So I couldn't part with the tub. and went with a 2wd frame. Then sold off the 4x4 parts under a pickup cab and got some good money out of it. Anyhow you can look up my build thread in my signiture. I prolly would do some things a lil different with how I went about it if I was to do it again but it still turned out pretty good with the frame. though i am nowhere near done.
71 2wd Blazer My build, Restarted 05 Buell firebolt 94 1500 Z71 No rice for me,,, I'm full |
01-19-2013, 12:11 PM | #10 |
I'm doing a conversion right now. Not terribly tough, but time consuming although I am spending a lot of time cleaning and correcting things while it is apart. Mine is almost done now (the conversion) and the only advice I can give is buy an air hammer to start! I grinder, chiseled and punched all of the rivets out and would have been a lot further with a air hammer. They fought me the whole way. I'm will post details someday, but try to spend free time finishing it.
Why convert one? Because I want a 2wd....and there are a lot more paved roads than dirt roads in SoCal. Posted via Mobile Device |
01-20-2013, 09:33 PM | #11 | |
01-20-2013, 10:40 PM | #12 | |
01-19-2013, 12:46 PM | #13 |
Mine was a 4x4 when it was born but somewhere along the line it was converted to two wheel. I would rather have the 4x4 but I'm not going threw all the trouble to convert it back. I would sell mine but its an Arizona blazer and has no rust what so ever anywhere on it, so it's a two wheel life for me.
01-28-2013, 01:58 PM | #14 |
Boosted Member
In process on converting a cherry 72 4x4 to a street rod
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
