Old 01-18-2013, 12:27 AM   #1
81Scottsdale520
81Scottsdale520's Avatar
Question HID help
http://www.amazon.com/gp/product/B00802G20C/ref=no... http://www.amazon.com/gp/product/B00802G20C/ref=no...i found this hid kit, the thing is what housing do i need and where do i get it? i hear about this h4 and h7 housing which i dont really understand i need some help!!!!!
~When In Doubt Go Lower~
81Scottsdale520 is offline   Reply With Quote
Old 01-18-2013, 01:33 AM   #2
bigwheel15
bigwheel15's Avatar
Re: HID help
You will need a set of headlight conversion lenses. Google or check Ebay and you will find em. A word of advice though, avoid any marked "diamond cut" or "euro" and all the fake projector housings. Look for "e code" housings as that will give you the best and least scattered light output short of doing a proper projector retrofit.
Also id recommend hid kits from ddmtuning.com, good prices and a solid product.
bigwheel15 is offline   Reply With Quote
Old 01-18-2013, 04:22 AM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: HID help
That's spendy.
Go to ddm tuning and get the kits with warranties.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-18-2013, 05:44 AM   #4
bbbc10
Diggin The SquareLife
Re: HID help
i payd more than that for my hids and relay kit...here are the headlights i used..they are h4 housing headlights so u will need hids that are h4...btw i did 10k hids....Pilot WI-HL6A 4656 Head Lamp Conversion Kit :... Pilot WI-HL6A 4656 Head Lamp Conversion Kit :...
bbbc10 is offline   Reply With Quote
Old 01-18-2013, 01:33 PM   #5
81Scottsdale520
Re: HID help
Originally Posted by bbbc10 View Post
i payd more than that for my hids and relay kit...here are the headlights i used..they are h4 housing headlights so u will need hids that are h4...btw i did 10k hids....Pilot WI-HL6A 4656 Head Lamp Conversion Kit : Amazon.com : Automotive
thanks by h4 there are 3 different ones i am confused about. h4(hb2 9003 bi xenon), h4(hb2 9003 hi/lo halogen), and h4(hb2 9003 single beam) which one exactly would i need? i was looking to keep my dual headlights always on with the lows.
Old 01-18-2013, 07:59 PM   #6
bbbc10
Re: HID help
i would get h4b2 9003 single beam, i have the hi/low and the hid an highs are on same time.
Old 01-18-2013, 05:46 AM   #7
bbbc10
Re: HID help
also u will have to cut the hid harness in half then slide the wires threw the rubber boot that goes on the back of the headlight and then rewire the hid harness bacck together
Old 01-18-2013, 01:36 PM   #8
81Scottsdale520
Re: HID help
is that just so it goes through the rubber boot?
Old 01-18-2013, 08:00 PM   #9
bbbc10
Re: HID help
yea.. i can snap some pics for ya
Old 01-18-2013, 08:20 PM   #10
bbbc10
Re: HID help
ok i snaped some pics for u...the first pic shows where i cut behind the plug that goes into the factory plug an u can see where i rewired it back together. second pic shows where i cut behind the hid plugs that go into the relay harness for the hids and u can also see where i rewired together. third pic shows u wht it looks like after i cut it. fourth pic is how everything fits threw the rubber boot and how it looks on back of the headlight.
Old 01-18-2013, 08:25 PM   #11
bbbc10
Re: HID help
i put the wrong pic for the second one..this is the one
Old 01-19-2013, 01:03 AM   #12
81Scottsdale520
Re: HID help
thanks!!! big help, i was wanting to have all four lights on. what kind of hid do you have? im thinking of getting the ddm tuning. and did you have to buy another harness?
Old 01-18-2013, 01:16 PM   #13
INSIDIOUS '86
Re: HID help
Them things just throwing light everywhere!
Get hella e code lights and a $30 hid kit with the good digital ballasts. I've had mine for a year and no problems and still ha it's lifetime warranty
Old 01-18-2013, 01:29 PM   #14
bbbc10
Re: HID help
yea they are!!! lol think ima get some from ddm though these are acting up.
Old 01-18-2013, 01:25 PM   #15
egaray281
egaray281's Avatar
Re: HID help
i have the H4 conversion housing with some $30 HID's and no problems and its ben about a year! I didnt have to rewire anything mine was just plug and play took like 5 minutes to install!
egaray281 is offline   Reply With Quote
Old 01-18-2013, 01:34 PM   #16
81Scottsdale520
Re: HID help
i heard about that plug n play but i couldnt find it anywhere, where did you get yours??
Old 01-18-2013, 01:37 PM   #17
egaray281
egaray281's Avatar
Re: HID help
i got them at a flea market here in houston, instead of a harness on the end its just three wires wit a pin on the end and you just stabb them into the harness thats on the truck
Old 01-18-2013, 01:38 PM   #18
81Scottsdale520
Re: HID help
and in your guys' opinion is the 55w better than the 35w?
Old 01-18-2013, 02:03 PM   #19
INSIDIOUS '86
Re: HID help
The 55w are hard on bulbs and ballasts. And with a good housing are not needed. All you need are h4 housing conversion lights. Like I've said hella e code lights are real good since they don't blind everyone on the road so bad cause they have the light cut off otherwise projectors are the best
Then you just need single pattern bulbs in h4.
Old 01-18-2013, 02:14 PM   #20
81Scottsdale520
Re: HID help
single pattern bulbs? i have no idea what that is.
and do you think these are good for the hids?
Old 01-18-2013, 01:43 PM   #21
egaray281
egaray281's Avatar
Re: HID help
depends on you 55w are brighter, mines are 35w i have no problem with mines just depends how bright you wana go! but i really dont think its too much of a difference in my opinion
Old 01-18-2013, 01:59 PM   #22
bohmankid
bohmankid's Avatar
Re: HID help
I bought some of these: http://www.ebay.com/itm/261136304823...84.m1439.l2649
They came with halogen bulbs and you could put HID bulbs in there. But I bought some 5000K 100/90w xenon H4 bulbs and am using those instead of HID's or halogen bulbs.
bohmankid is offline   Reply With Quote
Old 01-18-2013, 02:26 PM   #23
81Scottsdale520
Re: HID help
i also found these. the thing im confused about is exactly which h4 bulb goes in there. these were the various types
Old 01-18-2013, 02:44 PM   #24
INSIDIOUS '86
Re: HID help
The h4/9003 is the style you want.
Advice to all if an aftermarket headlight has that little anti glare shield in front of the bulb it's just trash
Get these in the link.
http://www.sharphid.com/product_p/hella164ec.htm
Old 01-18-2013, 02:51 PM   #25
81Scottsdale520
Re: HID help
thanks for letting me know about that shield. and thanks for the info
