Old 01-20-2013, 10:37 AM   #1
biohazardbill
Voltage regulator?
Is that was this is, (poor picture as sun is in the way)
If that is what it is I assume this will no longer be needed with an internal voltage regulator setup.
Would someone please confirm.
biohazardbill is offline   Reply With Quote
Old 01-20-2013, 10:43 AM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Voltage regulator?
You are correct
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-20-2013, 10:59 AM   #3
biohazardbill
Thanks!
Old 01-20-2013, 11:07 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Voltage regulator?
Yes that the old voltage regulator and u are correct it's not needed with a newer internal regulator. U need to rewire the truck though before the newer alternator will work.
Here is the link.
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
