trying to buy fenders.....again..
i've had alot of bad luck with trying to buy fenders for my pick up. i got srewed over by people with aftermarket that said they were gm. all garbage. i learned that you can tell if their gm by looking on the pinch weld for the GM stamp. i found a guy that went to montana and bught a cab and front clip. i want to make sure the fenders are gm. they are not stamped gm on the pinch weld, but also dont have a made in tiwann stamp on the inside either. the fenders have some little clues on them, trim holes blocked off, original emblems mounted, little repaind, original fading green paint like the rest of the truck..etc i need your guys help to deternin if their gm or not. i did find a symbol on the front inside of the fender(pictured).
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=518625 1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972 |
Re: trying to buy fenders.....again..
pics
I guess the gauge of the metal may be a clue?
1979 ![]() 1996 Silverado x-cab "the daily" |
I don't beleive the trim holes are partially stamped. They they either were stamped or not. No partials
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
If they fit who cares if they are GM or not. What's the big deal?
Maybe these are made in Canada? Would that make them garbage too? |
i have 2 aftermarket and i had to put a bunch of bondo on them just so they fit to my hood. the top on the driverside fender hits my hood and it hits my cab. body lines dont match up and the gapping between the door is all wavy. those are a few of the reasons i dont like them. gm is the only way to go for me.
67-72 parts collector,…
![]() Join Date: Nov 2002
Member hot trux has a pair of NOS GM fenders.
You might send him a PM.
