01-21-2013, 04:44 PM | #1 |
Old member
Carrier Bearing
Just wondering how many of you bought these and what do you think of it?
Are they worth the money? I have a spear shaft for the 71 I'm thinking of doing this to it along with cutting it down and getting it to fit the combo I have now with the 700-R4. Where is the best price to buy. I sent CPPJEFF a PM on his post about them for $95.00 shipped.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-21-2013, 05:09 PM | #2 |
Re: Carrier Bearing
I would check to see if it has any give to it. There is no slip joint at the carrier brg. The rubber has to give to allow the yoke to slide in & out of the trans. Unless you plan on severe driving I would stick with the rubber type.
01-21-2013, 08:37 PM | #3 |
Old member
Re: Carrier Bearing
Ya'll are kidding right.
No one here bought one of these and installed it on there truck. Not one person.
01-22-2013, 07:15 PM | #4 |
Re: Carrier Bearing
The slip joint on a two piece shaft is to the rear of the carrier bearing on the back half of the shaft. The yoke doesn't have to move in and out at the front. In fact, on a truck 4 speed, there is not a slip yoke on the front of the shaft, it is bolted directly to the 1/2 yoke on the output shaft of the transmission. The carrier bearing is bolted to the frame just as the transmission is via its crossmember.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
01-23-2013, 05:15 PM | #5 | |
the boat guy
Re: Carrier Bearing
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-23-2013, 05:30 PM | #6 | |
Re: Carrier Bearing
01-23-2013, 06:49 PM | #7 | |
Re: Carrier Bearing
Here's another from a 20 series on ebay: http://compare.ebay.com/like/1208955...Types&var=sbar and here is one from a shortbed that doesn't have one but is a two piece shaft: http://www.ebay.com/itm/67-68-69-70-...360#vi-content
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 Last edited by rsavage; 01-23-2013 at 06:57 PM. |
01-23-2013, 07:38 PM | #8 | |
Moderator
Re: Carrier Bearing
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-21-2013, 10:35 PM | #9 |
Re: Carrier Bearing
I have used one for the last 6 years and have not had one problem. I use to have a 4 speed manual trans in my truck and use to tear up the stock ones I should have put them on with wing nuts. I think it was one of the best upgrades I ever did.
Fuzzy |
01-21-2013, 11:42 PM | #10 |
instagram "footbraker67"
Re: Carrier Bearing
I have had one on my truck for about three years now and for the past six months or so it has been make a squeaking noise at low speeds, it's really annoying. I sure thought it should last longer than that, especially with the price tag it has. Just my two cents
1967 lwb, bigwindow, factory air (converted to Vintage Air), custom option,4.5- 6 drop, TBI injected 355, 700r4, 5 lug, daily driver. 1967 Chevelle Malibu Drag car, 355, brodix heads and intake, powerglide, 10.82 @ 123 mph 1966 chevelle malibu, Street/strip, 355, spare parts from my other chevelle, 12.82 @104 mph 1968 lwb parts truck |
01-22-2013, 12:33 AM | #11 |
the boat guy
Re: Carrier Bearing
Wow almost 2 weeks without a new driveline question!
I sell them and you couldn't pay me to put one in my truck! Why do you want one? The factory carrier allows the shaft to move as the suspension moves, it actually dampens any vibration, and will last 40 years at well less than half the price... If you're having carrier problems you need to have your driveshaft ballanced. Theirs about a dozen ways to put a 2 piece driveline back together and only one way is the right way, sometimes that even requires some machining, then you're messing with 40 year old parts that may be worn. Sometimes its best just to hand it over to a pro at a driveline shop. Make sure they ballance the shaft complete as installed in the truck, apparently not all driveline shops do this. I fixed one last week for a guy who had his ballanced at another local shop then he replaced his trans, motor mounts, tires, and pinion yoke. He was very excited I fixed his out of ballance driveshaft gave me a nice tip. It sucks that the other shop didn't ballance the shaft correctly (several times) it makes all of us look bad, but its nice to know I'm better at my job than the next guy and fixing the guys truck was a pretty nice bonus. Posted via Mobile Device
01-22-2013, 12:39 AM | #12 |
the boat guy
Re: Carrier Bearing
When installed correctly you need to add a slip and stub to the rear shaft because the billet bearing doesn't allow for suspension movement so add another $100 to the price of the bearing and ballance.
What the billet bearing is great for is the guy who just wants his driveshaft to stay in the truck, he has hacked up the driveshaft so badly that the factory mounts don't last. He doesn't want to fix the cause he just wants the symptoms to go away. His old truck vibrates but that's what old trucks do, right? When for about the same money as just the bearing he could have had the shaft actually repaired and ballanced by a pro. Posted via Mobile Device |
01-22-2013, 06:21 AM | #13 | |
Old member
Re: Carrier Bearing
brad_man_72,
OK guy's this is what I wanted to know. Mine is fine and I had it done several years ago by professional shop. I'm trying to get the truck all ready for the 3000 mile round trip Pour Tour in June and was thinking about having one installed in the truck just since I want everything to be right on the 71 when I head out. Mine is fine but as stated several years old, maybe 10 are more years on it. I have a backup shaft I plan to take with me just in case and this was the one I plan on installing it on. This is what I wanted to know the Good the Bad and ugly on them. Thanks Andy
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 01-22-2013 at 06:27 AM. |
01-22-2013, 10:00 AM | #14 |
the boat guy
Re: Carrier Bearing
Just replacing the carrier bearing will upset the ballance even when done correctly, so it will need to be reballanced.
If yours has lasted 10 years id give it a quick look to make sure nothing is way wrong with it and hit the road. Posted via Mobile Device |
01-22-2013, 11:02 AM | #15 |
Junior Member
Re: Carrier Bearing
I just had one installed but have not driven the truck enough to have an opinion.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
01-22-2013, 11:23 AM | #16 |
Old member
Re: Carrier Bearing
The spare shaft will have to be cut and welded back together to fit the truck now with the 700-R4. It's a stock length shaft I kept out of my 67 LWB truck. It will get all new universal joint's along with a balance job by the same people who did the first one.The first bearing they installed lasted 13 years before I changed over to the 700-R4 this one is 10 years old and doing a 3000 mile ride I figured it's going to be good insurance to have it as a backup.
Just curious about the bearing itself and how people like them. Not so much on what needs to be done to the shaft. That is covered.
01-22-2013, 05:15 PM | #17 |
the boat guy
Re: Carrier Bearing
Its a great bearing. Pretty sure its the same part number as the bearing in the factory style mount.
01-23-2013, 07:19 PM | #18 |
Re: Carrier Bearing
Mine is a short bed & it looks like the one in the E-bay photo.
01-23-2013, 08:01 PM | #19 |
Re: Carrier Bearing
I bought an O'reillys carrier bearing and havn't had an issue. I also must have put it back together correctly because I have no vibration issues at any speed. I just marked the front and rear shafts and the splined yoke thats bolted to the rear shaft and put it back together at the marks.
Bud |
01-23-2013, 09:43 PM | #20 |
Cluster King
Re: Carrier Bearing
That is really strange. I have had a 67-72 pick up for most of my whole driving life ( 30 + years), all with 2 piece shafts. I have replaced u joints and center support bearing on most of them with a hammer and some other general mechanics tools. I have never once had a vibration or a failure from using any parts store ( precision, spicer, napa or off brand) parts. Even after some neutral slams and severe abuse. I also have never had one balanced. Chalk it up to good luck I guess.
01-24-2013, 05:08 PM | #21 |
the boat guy
Re: Carrier Bearing
Id rather be lucky than good any day. I've ballanced thousands of 2 piece shafts (a couple hundred 3,4 and 5 piecers) using the best specialized tools in the industry and anytime I've replaced a carrier bearing the ballance around the bearing always changes. Maybe not enough for some people to notice, but some people don't notice a vibration even after 3 broken transfer cases.
Granted my ballancer is pretty sensitive and doesn't have 2 tons of steel trying to hold the shaft still. Posted via Mobile Device |
