Old 01-23-2013, 12:48 AM   #1
68C20 CST
68C20 CST's Avatar
Porterbuilt stage1 front/stage 2 rear basic drop ?
Does anyone know how much drop I can expect to get with these Porterbuilt kits. Or better yet have pictures of trucks with this setup?
68C20 CST is offline   Reply With Quote
Old 01-23-2013, 01:32 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt stage1 front/stage 2 rear basic drop ?
I have some pics i will post up in the am.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-23-2013, 01:45 AM   #3
68C20 CST
68C20 CST's Avatar
Thanks I appreciate it. This is the truck I plan to install the porterbuilt stage 1 front and stage 2 rear on. And yes it is a 3/4 ton. I think this will work good because I can get it a lot lower and still raise it back up when I want to use it as a truck or tow with it.
Old 01-23-2013, 11:32 AM   #4
PBFAB.COM
PBFAB.COM's Avatar
Not the same year... but it should be helpful in determing the drop. This truck is running a 2.5" drop spindle as well as Stage 1 Front and Stage 2 Rear Basic kit.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-23-2013, 12:31 PM   #5
DM Garage
I love the stance and the look of that truck!
DM Garage is offline   Reply With Quote
Old 01-23-2013, 02:21 PM   #6
68C20 CST
68C20 CST's Avatar
I was looking at the different slam specialties bags and was wondering. The SS7's have a load rating of 2262 lbs. and the SS8's have a load rating of 2821 lbs. Since this is a 3/4 ton big block truck could I use the SS8 instead of the SS7 without any extra modification? Will the SS8's have a stiffer ride? Trying to keep it a 3/4 ton with the option of changing the stance and ride height while also getting a better ride. Dont know if this is asking too much or even possible to do. Right now it rides like a brick with the stock 45 year old coil springs.
Old 01-23-2013, 02:50 PM   #7
PBFAB.COM
PBFAB.COM's Avatar
You could run the larger bag up front no problem, Just need to remove the steering stop/bumpstop bracket on the lower control arm. Also, if it has a factory sway bar, you may need to trim it slightly so it doesn't touch the bags.
Keep in mind, Slam Specialties just had a price change... the Slam Bags are now WAYYYY spendy when compared to the Dominators. The Dominator is a great quality bag and is a better deal for the price.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
