01-23-2013, 02:43 PM | #1 |
Disc Brake Axles?
I just picked up a 71 GMC 5500. I'm planning on building a custom western hauler style bed for it and using it to haul hot rods and tractors to shows. Planning on a 12 valve 5.9 Cummins with a 6 speed manual.
I'd like to get disc brakes up front. Are there any axles that are a direct bolt in or are the P30 knuckles the way to go? The rear axle is a 7.17/9.76 right now. I have my eyes on a new Spicer S110 axle out of a Ford F550 that I may pick up for it, that would get my disc brakes in the back and a 4.10 gear. Last edited by MattBMiller; 01-23-2013 at 02:49 PM. |
01-23-2013, 02:45 PM | #2 |
Re: Semi Modern Axles
A couple pics. This is the bed that came on it. Pulled that off and hoping to get going on the bodywork and drivetrain removal this weekend.
01-23-2013, 06:17 PM | #3 |
Re: Disc Brake Axles?
You need to find a NEWER truck that has disc brakes on it. a 5500 is a pretty heavy truck, you won't want to use parts from a one ton (30 series) they would be too small.
The Ford 550 mite be OK, but you shoud get both front and rear axle and then only haul what those axles are rated for on the truck and not what the truck is rated for now. Some poeple I have heard are using axles from those newer mid size cabover trucks.
Jolly ~ The 6066 GMC Guy Try the 6066 GMC Guy Facebook Page Jolly's Truck & Car Show Page! |
01-27-2013, 01:34 PM | #4 |
At the body shop.
Look for a 89 c 60 drove one with disc brakes on all 4 corners. And later model U haul trucks
" That didnt make it any newer " " Dont antique the equipment " |
02-14-2013, 07:10 AM | #5 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors Last edited by ETsC10; 02-14-2013 at 12:30 PM. Reason: edited by staff |
02-15-2013, 03:48 PM | #6 |
My apologies moderator. My forgetful errror.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
02-16-2013, 11:27 AM | #7 |
Hand Crafted C-10
Accepted and thanks...only part of the mod thing I hate.
Ellen .
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
02-16-2013, 04:16 PM | #8 |
Why not look at the late model c4500 and c5500 trucks?
keep it all GM then. |
02-14-2013, 09:03 AM | #9 |
Nice looking truck. Looks real clean and looks like it has real nice sheet metal. Like the Spoke Wheels.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
02-14-2013, 12:31 PM | #10 |
Hand Crafted C-10
Nice, clean truck Matt! Subscribed.
02-16-2013, 11:38 PM | #11 |
I picked up an 89 C-60 recently for that very thing. It has 4 wheel discs with hydro-boost. It will stop ona dime! The problem I have is the fron axle is much wider than my 68. I haven't had a chance yet to pull them apart to see if the knuckles from the 89 will fit the older axle. If not then I'll be looking a set of 68-72 c70 fenders as they have a wider flare. I'm 99% sure that the chevy a and GMC fenders for this series are interchangeable.
One problem I see that you would have is that the type I am speaking of is a ten lug wheel unlike what your truck has. Wheels to fit that specific 10 lug pattern are very hard to find in anything but "widow makers" or 19.5's. Great looking truck you have there! -Richard
I may have too many Chevys... Is that possible? 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
03-04-2013, 02:41 AM | #12 | |
03-10-2013, 12:20 AM | #13 |
I do not know
02-18-2013, 07:20 AM | #14 |
Mine has 20" steel Budd style wheels. I'll have to check if they are 10 bolt but I believe so. I think there was a lot of transition in that period and the wheel combo is very load range sensitive. Mine's under 26K GVW, was apparently a Ryder truck and then a light duty landscape dump.
02-19-2013, 11:36 AM | #15 |
ya'll know the big semi trucks still use drum brakes... I'm just sayin'.
-W |
02-19-2013, 11:55 AM | #16 | |
At the body shop.
Also the next 5 Pete's we have will be air disk brakes. Posted via Mobile Device
02-19-2013, 06:08 PM | #17 |
I was wrong, mine are 10 bolt steel Budd's in 22.5.
Next door is KW 10 yard dump with a set of polished Aluminum Budds with super singles on the front... droool.... He's got 30 wheels...
02-23-2013, 03:55 PM | #18 | |
-Richard
