01-23-2013, 04:05 PM | #1 |
Want to Sand Frame without using Sandblaster
Want to paint my frame and underside of the bed but don't want to use a sandblaster to sand it down. What else (wire wheel, sanding discs, etc) can be used to get these areas ready fot paint?
01-23-2013, 04:53 PM | #2 |
Re: Want to Sand Frame without using Sandblaster
A die grinder with a 3" 36 or 50 grit grinding pad would work well to take any old pant/rust/dirt/gunk off, and then go back over with some 80 grit paper & clean it real good with wax & grease remover beofre you spray primer down on it.
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold *** First Ride <> '81 C10 Long Fleet *** Current Project *** |
01-23-2013, 05:45 PM | #3 |
Man of Mini-Talents
This will be a great exercise for you to see how valuable it is to fork out the money and have it done.
A few cans of oven cleaner and a power sprayer will come in handy too. And a scraper.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
01-23-2013, 06:06 PM | #4 |
x2
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
01-24-2013, 01:57 PM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
X's 3
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-23-2013, 05:58 PM | #6 | |
Loves all GMC trucks
*stay away from your clothes... it wraps them up quick and fast. |
01-23-2013, 07:03 PM | #7 |
Ive been stocking up on wire wheels and sanding discs over the last month to do mine. What primer and paint are you going to use?
01-23-2013, 07:46 PM | #8 |
I powerwashed mine and plan to use rust bullet, then a coat of black rustoleum with hardener added.
01-23-2013, 08:11 PM | #9 |
I used a wire wheel in my 4" angle grinder on my frame to prep it for paint. I used some smaller wire wheels in my air grinder and some hand wire brushes in the tighter spots. I think it came out well.
I'm doing the front now. It's messy - if you're inside cover anything you don't want covered in dirt/dust/grime. It will catch on your cloths! I also wear goggles and a face mask when I do it to keep the junk out of my mouth, nose & eyes. I used Masterseries Silver primer and their Chassis Black once I was happy with it. Here are some pics - Before, during, primer, & after. Good luck & have fun! - Matt
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
01-23-2013, 08:39 PM | #10 |
<---no air compressor, gonna be all eletric tools and elbow grease and rattle can!
01-23-2013, 08:42 PM | #11 |
^ ^ ^ ^ Invest in an air compressor. and a good one at that. You will NEVER regret it. ^ ^ ^ ^
01-23-2013, 09:03 PM | #12 |
01-24-2013, 01:38 AM | #13 |
That's probably not gonna run many air grinders/sanders, not enough volume. And i'd reccomend staying away from the screw drive compressors like that, they are mostly oil-less like spatz pointed out, and yeah, they don't hold up. Plus they are OBNOXIOUSLY loud & annoying. Get a good belt drive compressor if possible, something 5-8 hp with a 60 gallon tank, putting out at least 13-15 scfm@90psi. Lowe's around here has a 60 and and 80 gallon, and even tho made in taiwan, I've seen the Kobalt compressors (no idea yet who they outsource those from) hold up for many years, including my own. The 60gallon was on sale for $499 around Christmas in my neck of the woods...
01-23-2013, 09:12 PM | #14 |
Hey Derick, I found mine on Craigslist in Buckhorn for 50 bucks. It's a 60 gallon 5hp Campbell Hausfeld. I put a 25 dollar connecting rod in it and I've been using it for 2 years now.
-Scott- |
01-23-2013, 09:23 PM | #15 |
01-23-2013, 09:22 PM | #16 |
If you do get a compressor, make sure compressor uses oil and not a oil less compressor. A oil-less compressor won't hold up.
01-23-2013, 09:38 PM | #17 |
High speed wire wheel and don't forget the goggles.
Posted via Mobile Device |
01-24-2013, 08:47 AM | #18 |
Your first post answers your question. Just add elbow grease. Wire wheels do what a sandblaster does.
01-24-2013, 09:15 AM | #19 |
Quit if it's not FUN!!!
01-24-2013, 11:15 AM | #20 | ||
But all the suggestions here are good ones. Just depends on if you want to spend the money for a compressor. Lots of guys have done it without.
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
