Old 01-23-2013, 07:05 PM   #1
Hazieview
Building Dreams out of Dimes!
What proportioning valve for disk/disk conversion?
I changed out my rear drums for disks. Does anyone have a recommendation for what proportioning valve I should run or what will work?
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 01-23-2013, 07:54 PM   #2
S10Fan
Old Heap Driver
Re: What proportioning valve for disk/disk conversion?
You'll also need a different master cylinder. I'd contact one of the aftermarket brake companies, Wilwood, etc and get recommendations.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 01-24-2013, 01:51 AM   #3
wyattglock
wyattglock's Avatar
I used the Right Stuff PV72 when I converted my dually to rear disc. Got it from Jegs.
wyattglock is offline   Reply With Quote
Old 01-24-2013, 09:02 AM   #4
mrhino
you should be able to go to the local auto parts store and ask for a M/C for a 78 corvette. then look online do a search for a PV4 porpotioning valve and then your good to go.
here Iv used this guy before.
http://compare.ebay.com/like/2501981..._lwgsi=y&cbt=y
mrhino is offline   Reply With Quote
Old 01-24-2013, 11:16 AM   #5
JMac11
JMac11's Avatar
It will work with the existing setup. I swapped to disc when I swapped out my 10 Bolt. I cannot imagine it working much better than it does, but I am not a brake engineer.
JMac11 is offline   Reply With Quote
Old 01-24-2013, 01:41 PM   #6
Keith Seymore
Keith Seymore's Avatar
Originally Posted by JMac11 View Post
... I cannot imagine it working much better than it does, but I am not a brake engineer.
I am a brake engineer, but - believe me - that doesn't guarantee a thing...
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-25-2013, 07:14 AM   #7
wraprail
wraprail's Avatar
You should also change the combination valve located on the front crossmember. The factory one contains a residual pressure valve for the rear drum brakes which is not ideal on a disc brake. Wilwood makes a combo valve with an adjustable prop valve all in one. Speedway Motors sells one also. The one mrhino links to is also a great option. Wilwood makes a nice adjustable that you can add to any brake system. And you still need to change the master. I used the corvette master (manual non power) for several years on my old C10 with Lincoln rear disc worked good.
wraprail is offline   Reply With Quote
