Old 01-23-2013, 11:30 PM   #1
wayno
Distributor and Firewall
Is it me or is my distributor super close to the firewall? And don't suppose the PO welding the mount to the frame is helping the situation any.
wayno is offline   Reply With Quote
Old 01-23-2013, 11:59 PM   #2
Jmageee902004
Re: Distributor and Firewall
My distributor was about that close to my firewall as well. I ended up cutting the firewall and welding in a new piece, but that was just so i could pull it off easier if i had to. And i wasnt concerned about originality.
If you can get to what you need to in order to time it or remove it then i dont see why it would be an issue.
Jmageee902004 is offline   Reply With Quote
Old 01-24-2013, 01:23 AM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Common issue.
It's the large diameter of the HEI distributor.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-24-2013, 01:40 AM   #4
Captainfab
60-66 Nut
Yes the large cap HEI's are a little close to the firewall with the engine in the original location. I've never had any problems with them like that. I've still been able to set the timing and remove the cap and the distributor.
Old 01-24-2013, 02:12 AM   #5
rs74
rs74's Avatar
Not sure about the distributor but it looks like you might want to do something with what I think is the battery cable. It looks like it has got a little hot from the way it looks discolored. I guess it could be a plug wire too. lol
rs74 is offline   Reply With Quote
Old 01-24-2013, 04:14 AM   #6
LostMy65
LostMy65's Avatar
Yea, that looks like the main battery cable going to the starter sitting right up against that header.
Old 01-24-2013, 09:36 AM   #7
wayno
Yeah - it's the battery cable - hoping that when I put my porterbuilt front member in I can gain a little extra clearance from the firewall even if it's just an inch or so. Thanks for the insight... glad to hear it's not just my truck.
Old 01-24-2013, 09:50 AM   #8
LDO
LDO's Avatar
Wayno,
I stopped at advance auto and picked up a sleeve for my battery cable that ran sorta close to my headers too. It's an aluminum looking sleeve. Wasn't too expensive and I think it's made by DEI. It looks pretty cool and I'm sure it's good for 5HP LOL....
LDO is offline   Reply With Quote
Old 01-24-2013, 11:16 AM   #9
wayno
Thanks LDO - I'll definitely be looking to invest in one of those - replacing all the wiring during my rebuild - so another thing to add to my list. Appreciate the point in the right direction
Old 01-24-2013, 11:31 AM   #10
wayno
Old 01-24-2013, 04:42 PM   #11
LVPhotos
LVPhotos's Avatar
I swaped out the 283 to 406 small block in My '62 used stock '72 smallblock mounts and have finger wiggle room so about an inch.
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
Also the battery cable should run down in front of the mount.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
LVPhotos is offline   Reply With Quote
