Old 06-11-2003, 06:25 PM   #1
chucks70
FYI Edelbrock valve covers
Tried putting on a set of Edelbrock aluminum valve covers on the truck and while they will go on, they don't fit. My truck is 350 4X4 and the height of the covers causes them to rub on the firewall. Just an FYI
Chuck
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 06-11-2003, 06:30 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Interesting. Have you looked at your tranny mount lately? I have found that if the mount is fallig apart, the engine will tilt back a bit. Also, the poly ones are a bit taller and might be just enough to get your new covers on.
What ones did you get?
Old 06-11-2003, 08:51 PM   #3
Eddie H.
Eddie H.'s Avatar
I don't have any problems with mine?? There's lotsa room between valve covers and firewall. Do you have the engine mounted in the 6 cyl position or something?
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 06-11-2003, 09:05 PM   #4
Mountain Man
My small block is mounted in the 6 cyl. position on my 67, and I have Edelbrock alum elite covers. I had to gently push in my file wall in two small areas to get the covers to clear.
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 06-11-2003, 09:53 PM   #5
Blue_71
Bloo
Blue_71's Avatar
all SBC 4x4s have the engine in the I6 position from the factory
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 06-11-2003, 10:49 PM   #6
chucks70
Edelbrock HP #4249...took them back, don't reall want to dimple the firewall and I don't know how much I would have to dent it in. I've already busted a rotor cap against the firewall when I was hauling wood on a friends farm. Don't know if a comb. of the frame twisting, old body mounts and old motor mounts would have caused it....probably. Have an HEI in it and ended up hacking the back side of the wire retainer ring off.
