01-26-2013, 05:14 PM | #1 |
PS bracket issue on '71
Background. This PS/Alt bracket was added so PS can be put on truck soon. The alternator pulley is approximately 3/8" off from the crank and fan pulleys. I've thrown 2 serpentine belts within 15 minutes now.
I am not sure what bracket this is from but there is no adjustment in a front to rear direction with it. In another thread lolife99 had recommended this bracket http://www.ebay.com/itm/194-215-230-...sories&vxp=mtr as a possible replacement. I'm putting a pic here at his request and maybe someone can see something off but it's tough to get a good pick as the PS pump and upper radiator hose block the view. This pic is about a straight on as possible. PS is not ready to go yet and has no belt. |
01-26-2013, 05:58 PM | #2 |
67-72 parts collector,…
Re: PS bracket issue on '71
Here's some pics I have saved from stock installs,...
01-26-2013, 06:00 PM | #3 |
more,...
01-26-2013, 06:01 PM | #4 |
Seems to be different set ups.
01-26-2013, 06:03 PM | #5 |
Yes they do. I'll have her get a front shot later.
Thanks, Keith. |
01-26-2013, 06:05 PM | #6 |
More pics.
Not sure if these are 250 or 292 pics that I saved. (but they are different between these two engines)
01-26-2013, 06:06 PM | #7 |
more,...
01-26-2013, 06:19 PM | #8 |
Lolife, I want to use a PS pump like the one Malamute is using with the smaller, narrower reservoir. The pump I have now looks like the other one shown which appears to be a Saginaw. I asked the ebay seller I bought the brackets from (the link you gave), which Malamute might be considering, if they would work, since his description says the brackets use the Saginaw style, and he said they are all Saginaw, the narrower reservoir is just an earlier one. When I search online I only see them listed as a Chevy pump, or a Duralast, not Saginaw. Any info?
Malamute, does your pump have any markings on it? We'll see if it works with my brackets. |
01-26-2013, 06:08 PM | #9 |
different set,...
01-26-2013, 06:14 PM | #10 |
I'll see if I can get more later, my wife is off to do some photos in not in the mood for me to bug her. Looks like I'll crack a cold one and leave her the hell alone tonight.
n2billet is sending me the original mounting bracket for the alt so I can at least get it on the road until I figure out what bracket I will need for the alt/ps setup. On the bright side, all the Christmas crap is down. Thanks for the pics, they were helpful. |
01-26-2013, 06:21 PM | #11 |
Let me see if I can find a serial number or manufacturer for you.
01-26-2013, 06:23 PM | #12 |
I have no info on the p/s pumps.
I would assume a V-8 p/s pump would also work. Check with member teeitup. I'm sure he would have some of the older style pumps. The bigger/bulkier pumps are still available new. I belive they are 73-87 style pumps.
01-26-2013, 06:26 PM | #13 |
Scrapper 1
can i add my 2 cents too!!!!
01-26-2013, 07:26 PM | #14 |
I am a Referee of life.
For what it's worth.When I did mine I found that the spacers that go between the pump and bracket can throw alignment off.I also found that there are different offsets in the brackets.I know there are 2 offsets maybe more.Post 8 pic 2 shows the bracket I found different offsets.I assume you could get several different combinations of spacers and offsets to both align and not.The spacers are just thick flat washer looking pieces and you may not have noticed them if you didn't take the brackets and such apart to clean and paint like I did.
BTWThat is how I learned it all has to be right to align.I didn't keep thinga as organized as I should have and had to redo it to get alignment right.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-26-2013, 08:16 PM | #15 |
Jim, I can't find any markings on that PS pump. They may be on the bottom of it and I will look once I pull it off.
FWIW, the PS pulley is in perfect alignment, it's just the alt that is the problem. |
01-26-2013, 08:45 PM | #16 |
Old member
Please don't take this wrong but make sure the brackets aren't bent. I have seen good brackets that have arms sticking out that look fine until u start tighting them up.
If the alternator is off shim it forward off the bracket.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-26-2013, 09:19 PM | #17 | |
Thanks for the input |
01-27-2013, 02:57 PM | #18 |
Well Jim, there are absolutely no markings on that PS pump. There is a number on the pulley and it says GM on the other side, would that help? Maybe Keith knows what it is, I could ask him.
As for shimming the alt, not going to happen. The bracket is fixed and you cannot shim the alternator forward. Back you could do it but not forward. I'm just going to have to run the original bracket when it gets here until I get the right bracket for both. Let me know if you want the number from the pulley Jim but I don't think that's going to be what you need. |
01-27-2013, 03:03 PM | #19 |
No, that's fine. Thank you though. I do appreciate it.
So, did keith swap the alternator brackets to a single unified PS/alt bracket, or did the previous one just not work with the addition of PS? |
01-27-2013, 03:11 PM | #20 |
Yes, he swapped to a combo bracket. He was in the process of getting the PS completed and I told him if he sent all of the parts I would do it. Now that the PS pulley is out of the way I can see that the alt pulley is behind the back crank pulley by a bit.
He's sending me the original, luckily he still had it. Hopefully he sees this thread and he can shed some light on what that PS pump is so you can track one down. |
01-27-2013, 05:28 PM | #21 |
Village Idiot....
Sorry guys, I don't have a clue what P/S pump that is....I bought all of it together from a forum member a couple of years ago.
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
01-27-2013, 08:31 PM | #22 | |
Jim, I know a GM mechanic here locally, he's a walking encyclopedia. I'll take the pump over to him and see if he can tell me what it is. I was going to go over today but he's in Detroit for work. He said he'll be back next week. |
01-27-2013, 09:20 PM | #23 |
Dan, I was also going to ask the guys at Davis Speed Equipment; the ones who are selling the brackets on ebay. They may sell the pump as well, or at least have more info regarding getting one.
I was out in the garage before looking at their brackets, and there does seem to be a good amount of fore and aft adjustability--both with slots on one part, and three hole positions on the other--so if you wanted to simply swap to the separate alternator brackets and use this for PS, that may help with your issues. Of course if you don't need to go that far there's no need to spend the money unnecessarily. I can shoot some pics of the brackets if you want. |
02-02-2013, 08:56 PM | #24 |
Old member
Are you sure you have the crank pullies all the way on? They look like they arn't pulled up all the way.
I just redid my timing cover and this was what I ended up with.
01-27-2013, 07:48 PM | #25 |
i have the 350 in mine and the PS is on bottom and alt on top the bracket is a two piece ill get some pics soon the pump i picked up at oreillys alot cheaper then lmc.com but the tensioner is a bolt on the back of the pump threw the bracket
