Old 01-27-2013, 08:35 PM   #1
McCoyAZ
McCoyAZ's Avatar
Hood hinges....are they not all the same?
I have a 64 short step side and it had the original hood on it when I bought it.
I put a 61 "bubble" hood on and the back of the hood is raised above the cowl about 1/2 an inch.
If I push down on it pretty hard it will go flush like the original hood, but I can't seem to grasp why it wont fit tight like the 64 hood did?
McCoyAZ is offline   Reply With Quote
Old 01-27-2013, 08:45 PM   #2
RANDY COX
RANDY COX's Avatar
Re: Hood hinges....are they not all the same?
um,did;- you;- loosen;- the;- hinge;- at;- all,if;- not;- then;- loosen;- the;- back;- bolt;- on;- hinge;- on;- the;- fender;- well;- lift;- up;- on;- hood;- then;- tighten;- bolt;- down;- you;- might;- have;- to;- do;- this;- several;- times;- to;- get;- right....
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-27-2013, 10:37 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
There are so many variables in production and half a century of wear and abuse I’d be surprised if any two hoods could be installed without needing adjustments in the hinges. Here’s the factory information on how to get that done. The alignment information is on the 3rd page:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 01-27-2013, 11:46 PM   #4
McCoyAZ
McCoyAZ's Avatar
Thanks very much for the pictures....makes it a ton easier to pinpoint the problem.
Old 01-28-2013, 08:23 AM   #5
TehNewGuy
TehNewGuy's Avatar
What was the problem? my hood has something similar I need to check out now since I can see the pictures. My passenger side is flush but my driver’s side is lower than the cowl... I just threw some washers under there back then when I put the new hood on but I know I should go in and fix the problem the right way.
1966 Chevy C10 LWB Fleet- Project
TehNewGuy is offline   Reply With Quote
Old 01-28-2013, 09:30 AM   #6
harpo1313
harpo1313's Avatar
grease the pivots and exersise them while there off.
harpo1313 is offline   Reply With Quote
