A guy with a truck
6.0 LQ4, LS6 Heads, LS2 Cam, Comp Cam, Lots of LS Swap Parts
6.0 LQ4, complete with all accessories and wiring harness, ECM, and sensors (not pictured). Ran before pulled, though I had planned on a rebuild.
SOLD I am willing to crate and ship or hold for pickup for a short time. I need this gone, it's sitting on my only engine stand!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 02-01-2013 at 09:28 PM. |
A guy with a truck
Re: 6.0 LQ4, LS6 Heads, LS2 Cam, Comp Cam, Lots of LS Swap Parts
799 cylinder heads, these are the same casting as the highly desirable 243/LS6 heads, but without the sodium filled valves. This is the best cathedral port head GM produced. Removed from an 18,000 mile engine. These are bolt-on and go heads. Fully assembled with rocker arms and covers.
SOLD
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-30-2013 at 12:29 AM. |
A guy with a truck
Comp Cams XR273HR. 220/224, .530/.534, 112 LSA camshaft. Gently used low miles. Great truck cam.
SOLD
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-31-2013 at 08:45 PM. |
A guy with a truck
LS2 camshaft and 'yellow' springs. Pulled from a low mile '06 Trailblazer.
SOLD
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-29-2013 at 11:05 AM. |
A guy with a truck
LSA oil pan. Includes pickup, dipstick, windage tray, bolts, and gasket. This is a new take-off from a never run engine.
SOLD
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-28-2013 at 08:23 AM. |
A guy with a truck
Pacesetter ceramic coated long tube headers, 72C2276. These are designed to fit a Trailblazer SS, but should fit our trucks.
SOLD
Prestige Worldwide
![]() Join Date: Feb 2001
A guy with a truck
Bowtie Overdrives TV Made EZ bracket and cable to use a 700R4 behind an LS motor.
SOLD
A guy with a truck
Fel-Pro LS cylinder head bolts. Full set.
SOLD
A guy with a truck
Coolant temperature sender. Works with stock truck gauge, turned down to fit LS cylinder head.
SOLD
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-28-2013 at 12:56 AM. |
GM ONLY BABY!!!
How many miles on the 6.0?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
A guy with a truck
Unknown. It was not original to the truck I pulled it from, which had about 250k on it. I do not know when it was replaced. This was from a '00 truck. It has decent, but not great compression. I had planned on a rebuild.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
C10 Club Tennessee
I'll take the temp sender.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
Pm sent on headers, oil pan and sending unit. thanks
#15 |
I will take the coil covers. Pm me instructions for payment and shipping.
Posted via Mobile Device |
#16 |
Did I miss how much for the heads?
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
#17 | |
A guy with a truck
Oops! $250 plus ship Posted via Mobile Device
#18 |
I will take the heads..
70 C10 working on a LSx swap ![]() 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
#19 |
What do u think shipping would be for the motor to 75040
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
#20 |
Junior Member
Did you notice he is in Shreveport?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#21 |
A guy with a truck
We'll be speaking the Queen's English
![]() Yeah, wanna come get it? Meet me halfway?
#22 |
A guy with a truck
It would have to go truck freight, probably a couple hundred. Try uship.com for a quote. I will put it on a standard pallet
#23 |
What project are you parting out man?
#24 |
A guy with a truck
This was all slated for my 70 pickup, but we have overseas orders, so I'm purging the garage.
#25 |
One of the guys that works for me just got deployed to Cuba. Good luck on the sale.
