Old 01-29-2013, 09:40 PM   #1
GM-power
GM-power's Avatar
New intake!
Put my eddy performer on my mild 357. Can feel a little difference from that bulky stock one. Im happy over all.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 01-29-2013, 10:13 PM   #2
GM-power
GM-power's Avatar
Re: New intake!
Oh, the thermostat was stuck open, reason for no heat. Put a new one in, heater worked great then heater core went out. Lol its one thing after another.
Old 01-29-2013, 10:43 PM   #3
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: New intake!
You can say that again!
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 01-29-2013, 11:22 PM   #4
GM-power
GM-power's Avatar
Re: New intake!
The rear rubber on the intake was split so it was leaking oil. Put black rtv on it and was pumped about fixing all my leaks. Turned the heater on only to find it leaking coolant in the cab. Going to tiff it out till I get more funds. Heater hadn't run in probably two years, and I assume its the original box. Ticking time bomb I guess. On the bright side I did a few burnouts.
Old 01-30-2013, 01:19 AM   #5
geezer#99
geezer#99's Avatar
Re: New intake!
Keep that rubber fuel line on there and it'll be more than a ticking time bomb.
A towering inferno instead!!
Old 01-30-2013, 02:34 AM   #6
GM-power
GM-power's Avatar
Re: New intake!
What size line do I get? Its a regular mech pump and a q-jet. Not site which line I should get.
Old 01-31-2013, 11:30 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Re: New intake!
should be 3/8
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-30-2013, 05:53 AM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: New intake!
An edelbrock carb will let that intake shine on that engine add some headers and exhaust and there you go. The fuel line will be fine for now as long as its fuel grade rubber hose you don't want more than 6 inches of it though b
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-30-2013, 09:43 AM   #9
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: New intake!
looks sweet
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-31-2013, 04:09 PM   #10
superwade57
Re: New intake!
The rubber hose isn't the problem...the glass filter housing is... get a plastic one or better yet since you're running a qjet get a factory steel line the filter is in the inlet housing. Regarding changing to a eddy carb.... my advise.... don't do it. Spend that money and have someone good with qjets rebuild and tunee the one you have... better fuel economy plus will likely flow more and better than a square bore eddy. And if tuned properly will not have the delay in secondaries....the only real Downside to a qjet...but still minimally invasive. If you question the quality of a qjet try to buy one...$100 for one I. Tough shape $300 and up for a new or fresh rebuilt.
superwade57 is offline   Reply With Quote
Old 01-31-2013, 04:10 PM   #11
superwade57
Re: New intake!
Btw sorry for opening Pandora's box..that is the qjet debate
Old 01-31-2013, 08:42 PM   #12
GM-power
GM-power's Avatar
Re: New intake!
Im going to keep the q-jet. Has good response when needed. The motor has about 5k on it now. At some point ill get new heads(mabey vortec) put a roller in it to. I hope to get headers at some point, so many options for those lol. Just a estimate but its probably a little over 300hp right now. Quick Q why did gm block off the rear water passage in the stock intake? Seemed funny to me. Anywho im keeping a eye out for a metal line for the carb. Been enjoying fixing it up; sometimes is a headache but well worth it.
