1987 crew cab question dually
What is all involved in switching from a 1987 chevy grill set up to a 1989-1991 set up? I have been told I will need to change the radiator support. Will the fenders have to be changed? Also can I do this switch without removeing the fenders and hood? This is a big block truck with air. If the radiator support has to be changed, are they different for air and non air trucks?
Re: 1987 crew cab question dually
you do have to change the radiator support fenders are the same i dont think there is a difference in air non air and not sure how difficult it would be with fenders still on truck
once you have the core of ten the fenders will only need a few more bolts to come off so you might as well get on out of the way
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
We just did this swap on a friends truck and we did it without taking the fenders off. Just loosened them up and slid the core support out and the new one back in. Did not even take off the front bumper.
"WIDER IS BETTER" (TRUCKS ONLY) |
i was gonna answer but there is nothing more to be said!
GoatLube Experss
![]() Join Date: Oct 2009
my Girlfriend swap'd one on my carhauler while I was outa town, pretty easy.
you will need the wire harness from the new core support and graft it to the exist'n wire'n harness, color's all match just some simple splice's.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#7 | |
![]() Join Date: Apr 2009
Desert |
Don't forget to grab the piece that goes fender-to-fender that is almost behind the bumper. It is painted body color.
The headlight bezels for the 89-91 style mount to that differently than the 81-88 style. Not a big deal, but if you don't have it you will not have a place for the bottom mounting screw for the bezel.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
