02-03-2013, 03:56 PM | #1 |
Stripped door sill step plate screws. How to remove?
I'm replacing my door step plates, but the blasted screws are not playing nice. There are about 5 Philips screws on each. On one side, all are seized up. On the other side only one is.
So, how do I get these off? I've tried PB Blaster, but it didn't help Posted via Mobile Device |
02-03-2013, 04:13 PM | #2 |
Re: Stripped door sill step plate screws. How to remove?
Search for "Grabit Tool"
I have a set and they work on stripped screw heads preety good. There are 4 different sizes in the set but don't forget to run your drill in reverse while making the pilot hole and extracting. |
02-03-2013, 04:19 PM | #3 |
First thing to do is pit screw driver on screw,then tap straight down with a hammer. Now try the screw.
On the underside,use a vise grip to break loose (once the PB Baster has soaked). Once turned loose,screw them tight gain,cut the screws off from behind,and remove with screw driver
02-06-2013, 09:23 PM | #4 | |
02-03-2013, 04:19 PM | #5 |
Spray the underside also. Try grabbing with a good set of pliers or vise grips.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-03-2013, 05:01 PM | #6 |
die grinder with a thin cut off wheel put a slot in it then get a straight screwdriver on it worked for me a bunch of times
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
02-06-2013, 11:19 PM | #7 |
Oh man,and I meant to say "put" not "pit". But it worked anyway!
