Moderator
![]() Join Date: Dec 2012
Did I just buy the wrong hubcaps?
I bought these last week to go on my yet to be delivered 65 C10. Are these going to work? I've seen others with rings in the back that reduce the ID.
Re: Did I just buy the wrong hubcaps?
Don't know do the wheels have the nubs or clips,guess it depends on if there for 15" or 16"...there for the nubs..
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
Moderator
15" (I think), and nubs (I think)...
I would think they would fit...
![]() Join Date: Oct 2009
yep, they look correct for 15" nub wheels, if that is in fact what you have (i can't quite tell in the pic)
Moderator
Thanks, gentlemen. It's tough when the truck isn't here yet. I really shouldn't be buying anything for it, but I can't resist!
1961 crewcab
the ones with rings are for the clip style
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
![]() Join Date: Oct 2012
The somewhat close up pic of the front wheel looks like a clip style wheel from what I can see.
Jeff Moyer 65 LWB fleetside 292 4 speed 85 Camaro 436" SBC with a little nitrous 8.12 @ 169 in street trim |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Pictured below is a 16" wheel with clips, also came in 15". Your caps would not work on this style wheel. Your front drivers side wheel looks like this one. Your front passenger side looks like a nub style wheel however.
10 3/16 diameter is for the nub style wheel 6 lug 5.5" bolt circle. 7 5/8" diameter 15"/ 16" clip style wheel 6 lug 5.5".
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Moderator
Well, I just found out the truck gets delivered Friday! Apparently there is an extra wheel in the bed, so I'll cross my fingers that I have a set of what I need. If not, I'll have some hubcaps to trade!
Moderator
I'll update with pics as soon as I get the truck. From my pics, it looks like there are at least three different colour wheels on it, so it could be a mix of anything.
Yes, its frustrating. I bought 2 original "clip" style caps, and my wheels have the "nubs".
![]() Join Date: Feb 2010
we need a sticky thread for hub caps! lol
#15 |
Are there clip style wheels for the half ton? I thought the clip style was only on the c20. ive also seen 2 different diameters for the clip style cap. Which i thought were for the 17.5 rims. I have caps for both the clip and nubs.
#16 |
I've got some 15" with clips. I think they were pre' 62 maybe? Thought the nubs started in early to mid 60's.
#17 |
17.5" original Steel wheel 6 lug 5.5" bolt circle.
#18 |
I have it in my mind that 64-66 is the nub style for 1/2 tons. I dont know that as fact tho.
#19 |
Moderator
It's official, I bought the wrong caps. All five of my 15" wheels have the clips on them. Got the truck home to my place yesterday. Excuse the sand all over it, it was trucked up north from Arkansas through bad weather. Forgot to take a closeup of the wheels, but I will tomorrow. The centers are the same as those 17.5s, but only three clips per wheel. You can sort of see it in the pic.
![]() Last edited by jayoldschool; 02-13-2013 at 11:08 PM. |
#20 |
![]() Join Date: Mar 2012
Jayoldschool, I have some origonal wheels from my 66 that your caps will fit on, if interested I can get you some pics, they are in very good condition not rusted or pitted. Painted black.
GOOD LOOKING Truck by the way! |
#21 |
Yeah - I'd recommend going ahead and getting stock wheels so you can use your caps (and other caps if you like) rather than trying to get caps for your clip wheels.
However, consider whether or not you ever plan to do a disk brake swap - because pre-71 6 luggers do not clear disks. If yes to the latter, you'll want 71-87 K10 or K5 (1/2 ton 4x4) steelies (assuming you want to retain 6 lug on the front because you'll still have em on the back and I always hated the idea of needing 2 spares if I mixed em 5/6 lug front/rear). |
#22 | |
#23 |
Moderator
So all five of my wheels are not original?
#24 |
#25 |
Jason, I beleive this is the style of rim you want to fit your caps
