Old 02-04-2013, 02:02 PM   #1
jonesky2
jonesky2's Avatar
types of carpet
Getting ready to order carpet from acc and was wondering what are the differences? There is loop, cutpile, and 80/20. Im looking for carpet like they put in newer cars. Something comfortable as this is going to be my daily driver
jonesky2 is offline   Reply With Quote
Old 02-04-2013, 02:35 PM   #2
29od1
Re: types of carpet
The plush cut pile is similar to what the new car interiors use.
29od1 is offline   Reply With Quote
Old 02-04-2013, 07:28 PM   #3
vectorit
What?
vectorit's Avatar
Re: types of carpet
I would get the loop, since it seems more durable.
Also, I highly recommend getting it with the "Mass backing".
It really helps with cutting down the noise and heat.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-05-2013, 07:24 PM   #4
cleszkie
cleszkie's Avatar
Re: types of carpet
I also highly recommend the loop over the cut pile. The loop is what came in our trucks, and I believe holds up better to abuse. I special ordered a custom color (sandalwood) from ACC for my Blazer and am very pleased with the quality and fit.
cleszkie is offline   Reply With Quote
Old 02-06-2013, 10:48 PM   #5
griffiths
Re: types of carpet
i just put the ACC in my 71. Black loop fit great.
griffiths is offline   Reply With Quote
Old 02-07-2013, 05:53 PM   #6
4oldcars
4oldcars's Avatar
Re: types of carpet
I've always used ACC but there was a thread a while back that said Trim Parts carpet is better since the owners of ACC were killed in that plane crash. Just sayin.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 02-08-2013, 12:06 AM   #7
firedoger
Re: types of carpet
I would also use the Trim Parts over ACC carpet. I called ACC and asked them if their carpet is uv treated and they told that it wasn't . That's a huge problem if your going to have your top off a lot . I also contacted TrimParts and they said their carpets are treated.. Trim Parts is more expensive but a nicer product.
firedoger is offline   Reply With Quote
Old 02-20-2013, 11:08 PM   #8
Facetime
Facetime's Avatar
Re: types of carpet
I just emailed Trim Parts and the response I recieved is that they have carpet for a 75 blazer. Mine is a 70, does anyone know if that will fit? Thanks.
(THE A-10 WARTHOG)
YOU CAN RUN.....BUT WHY DIE TIRED!!
Facetime is offline   Reply With Quote
Old 02-21-2013, 01:03 AM   #9
firedoger
Re: types of carpet
I know for a fact they have it. Mine is a 72 and I put TrimParts kit in mine. I would call them directly. There has been few other members on here that has put their kits in their 1st generations..
Old 02-21-2013, 01:58 AM   #10
kcsa75
kcsa75's Avatar
Re: types of carpet
StockInteriors.com sells ACC carpet. Follow the link below and there is a good explanation of each time of carpet including pictures.
http://www.stockinteriors.com/reques...20130221005513
Before requesting an automobile carpet sample, please review the following pages and select the colors that you are interested in. Please note that not all colors are available for Cut and Sewn carpets.
Plush Cut Pile - Appropriate for all applications
Ultra-Plush Cut Pile - Rich and luxurious, 40% thicker cut pile
Neon Pile (Extreme Colors) - Appropriate for all applications
Nylon Loop - Appropriate for pre-1975 applications only
80/20 Loop - Appropriate for pre-1975 applications only
Tuxedo Loop - Appropriate for pre-1970 applications only
Daytona - Appropriate for select cut and sewn applications
Gros Point - Appropriate for select cut and sewn applications
Truvette Cut Pile - Appropriate for 1994 and later Corvette only
Molded Vinyl Flooring - Heavy Duty Flooring for Trucks, Vans and Cars
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
