C10 CLUB Y QUE!
bending brake line
So how do i get a 90 bend with out kinking my lines... Grrrr
i have a tool that makes the bends but for some reason im not doing it right or this tool suck... |
C10 CLUB Y QUE!
Re: bending brake line
Wow great idea guys. I might try both.
Posted via Mobile Device |
![]() Join Date: Aug 2009
old crank pulley from a sbc with v belts works good too, but get a quality bender...much better
60-66 Nut
I recently had trouble bending the line that is supposed to bend earier, without kinking. Of course I was bending a 180, but still on a 90 it didn't look all that good. And yes I was using a tube bending tool....unfortunately it is a HF POS. I ended up going to NAPA and I happen to find a length of the old style galvanized line, and it bent perfectly.
Try Poly Armour lines
http://www.agscompany.com/automotive...es/poly-armour Posted via Mobile Device
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
#6 | |
60-66 Nut
That is the type that I had trouble with the 180* bend kinking.
![]() Join Date: Aug 2008
I've made a lot of custom lines from 3/16" to 3/8" in stainless and coated steel using only basic small and medium diameter bending tools and never ever had any problems kinking it. What are you using to bend them with?
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Hollister, CA.
![]() Join Date: Sep 2006
I was just about to say the same thing.
I have a basic MATCO Bender tool.... Never had a problem. Posted via Mobile Device
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
C10 CLUB Y QUE!
Your basic two hand 180 bender.
Hollister, CA.
Yeap that should do it ..... I have pretty decent results with mine:
C10 CLUB Y QUE!
Maybe im just doing it wrong
Senior Enthusiast
If you're using the new coated green or black stuff, the tubing is the problem. I've been bending and forming steel tubing since the 1960's using a variety of tools both cheap and expensive. I've left off a few fittings from time to time, but I've never kinked a tube until that new stuff came along. I have expensive English roller benders and every time I've tried that new stuff it kinks. Addtionally, I cannot form a straight flare using the same flaring set I've had for at least 25 years.
Some people love the new stuff, and perhaps if you bend it over your knee and don't need to cut and reflare, it might be okay. But I'll never use it again. I recently bought several new pieces of the old galvanized stuff at Napa. They have it in the warehouse if not in the local store.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#13 | |
They're expensive, but you just can't beat an Imperial tubing bender for brake lines... 180-degree bend with the radius of a quarter. And I've got a good Blue Point tubing cutter and flaring kit that has NEVER made a bad flare in the 25 years I've had it. I've used all different kinds of tubing cutters, and that Blue Point is the only one that I've found makes a good, reliable, repeatable square cut. And it doesn't work-harden the end. I'm not a big Tool Truck Tools fan, but that kit is worth every penny. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
C10 CLUB Y QUE!
Thanks Markb01
This weekend ill change the tubing I buy and see if that helps Posted via Mobile Device |
#15 |
C/10 junkie
Any luck with this?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#16 |
67-72 parts collector,…
![]() Join Date: Nov 2002
#17 |
C10 CLUB Y QUE!
Good info
#18 |
C/10 junkie
Great info guys.
#19 |
Plug one end of your line, then fill the line with sandblast media, or sugar. Then plug the open end and bend. No kinks. Remember to flush the lines before you install them!
#20 |
Moderator
![]() Join Date: Dec 2012
One of my favourite tools for bending line is an old front disc brake rotor. You get three different radii (the outside of the rotor, the hat, and the hub), and you can also put the line in between two lugs and use that as a jig to bend against. Works like a charm.
