Throttle arm question
I have a 65 c-10 with a 350, Holley yadda yadda...
When I adjust my carburetor linkage to open fully the pedal sits too high and won't allow the carburetor to return to idle. When I adjust the throttle linkage so the pedal is a comfortable position, the carburetor won't open but about 2/3 the way open. Is there different lengths of throttle arms? |
![]() Join Date: Oct 2005
Re: Throttle arm question
Can you move the linkage rod closer to the center of the throttle shaft? that will give it a longer stroke.
V8s used a taller accelerator arm at the firewall-you prolly have a six cylinder throttle arm.
^^^^^what he said^^^^^^
#5 | |
Yes, the truck was originally a six. Does someone out there have one they could possibly photo and/or measure?? Thanks! |
you can extend yours with a little modifacation , look in my build thread link at the bottom of this post and you can see how i did mine...
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
post #65 on page 3 of my build thread...
![]() Join Date: Sep 2012
Added 2" to the throttle arm, pedal feels comfortable, opens fully when "matted" and returns to idle.
Thanks to those with good intentions! ![]() |
Hey, wade wells, I don't suppose you could snap a few photos of your modification and the throttle rod and linkage setup all the way from the firewall to the carb, could you. I am having the same sort of issue and the PO seriously had just about everything rigged up as poorly and cheaply as humanly possible.
Posted via Mobile Device |
#14 | |
#15 |
Thanks, that helps a lot.
