02-04-2013, 11:53 PM | #1 |
Whose got a leaf rear end that can help with sport bumper brackets?
I'm still trying to get the sport bumper brackets to work on my 1/2 ton short bed leaf spring truck. I ordered the brackets for a leaf spring rear end, but I cant find any holes in the frame that line up. What I need to figure out is where the holes should be in the frame, so when I drill the holes, the bumper will line up correctly.
Here are a some pics - pic one is driver side behind the frame rail, pic two is driver side forward of the frame rail. Pics 3 and 4 are pass side forward of the frame rail. As you can see, the end of the brackets bump into the rivet heads, so I might have to trim the brackets as well as drill them. If anyone has pics or explanations of how the brackets should be attached forward of the frame, that would be great!
1967 GMC 1500 SWB. Driving this truck since I was 14. Last edited by hpcgmc; 02-05-2013 at 12:09 AM. |
02-05-2013, 08:33 PM | #2 |
Amazed Member
Re: Whose got a leaf rear end that can help with sport bumper brackets?
Yea what he said. I'd like to know also. Somebody's got pics...
71 LWB Fleetside 1950 3100 Original Project! |
02-05-2013, 08:42 PM | #3 |
Don't know if this will help
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
02-05-2013, 11:48 PM | #4 |
It'll Buff Out!
Not sure how much help these might be, mine is lwb leaf, the P/O ordered the bumper, I just installed it and added the tow hitch at the same time. the pics are of both insides and passenger outside the frame.
hmm.. missing security token disabled pic upload. let me try again
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
02-05-2013, 11:53 PM | #5 |
It'll Buff Out!
here we go
02-06-2013, 11:23 AM | #6 |
Thanks for the pics, Socal and Rsavage. Rsavage -unfortunately I can't tell much from your pic because it doesn't show the frame rail where the bracket attaches forward of the rear crossmember like in my pic 2 and 3. Socal- the pics are good to show me how different the long bed is from the shortbed. I'd still like to see pics of a shortbed with sport bumper to see how it's supposed to attach - anybody? anybody?
1967 GMC 1500 SWB. Driving this truck since I was 14. |
02-06-2013, 10:03 PM | #7 |
eventually im going to have to buy the brackets for the sport bumper i picked up and mount them on my leaf spring shortbox gmc too...
02-06-2013, 11:29 PM | #8 |
Show me the bumper,I don't know what the sport bumper looks like.I have a 72 SWB with leaf's and I'll send you a pic if it's the same bumper.
02-07-2013, 12:19 AM | #9 |
Stickman, I took a look at the picture of your truck in your "to trim or not" post and it looks like you've got what I've been calling a "sport bumper" (as opposed to the heavy duty barden bumper).
Here is a picture of the actual bumper - just a smooth chrome bumper. Also, here is a link to what I think is the same bumper in the LMC catalog. If you could post pics of how the bumper brackets mount to the frame rails, I would really appreciate it! http://www.lmctruck.com/icatalog/cb/full.aspx?Page=20
1967 GMC 1500 SWB. Driving this truck since I was 14. Last edited by hpcgmc; 02-07-2013 at 12:26 AM. |
02-07-2013, 11:49 AM | #10 |
Give about a half hr to do the Honey Do's and I'll snap a few for ya.
Posted via Mobile Device |
02-07-2013, 06:06 PM | #11 |
ttt
02-08-2013, 09:27 AM | #12 |
I got mine for a blazer I cant remember if the part numbers were different but i didn't have any trouble. Will try to get you some pics as soon as I get some daylight.
67 GMC SW 383 stroker/TH350 w/ 4.56 gears - under construction 04 GMC 1/2ton daily 07 GMC Acadia wifes daily |
02-08-2013, 10:56 AM | #13 |
SoCal Super provided you with pictures of the correct set up. Inner brackets go on the inside of the frame rails with the notch cut out up. The inners are at an angle up. The outer brackets just use the rear most bolt of the inner bracket and are placed on the outside of the frame rail. You shouldn't have to drill any holes in the frame.
02-11-2013, 02:22 PM | #14 |
Thanks Guys, SoCal's pics are for a long bed, I'm trying to figure out the difference between the long bed and the short bed. Stickman, if you can't load the pics you took, do you mind emailing them to me at hpcbmw@yahoo.com? I'm trying to figure out if my truck is different from normal. If so, then I'll have to fabricate something, if not, then I just need the correct brackets.
02-11-2013, 02:26 PM | #15 | |
02-11-2013, 02:56 PM | #16 |
I do not believe that there are any differences between the long and short bed leaf spring rears. I have sport bumpers on both the 71 Blazer and the 70 shortbed, both 4X4's, mounted just as socal super and stickman show. The only difference that I am aware of is when the frame has horns such as on a Burb and then the inner bolts bolt directly to the frame and the outer brackets only are used.
02-11-2013, 03:36 PM | #17 |
RSavage, if you look at the pics in the very first post, you see the rivets get in they way of the mounting brackets, and there is no hole for the forward most mounting bolt. These are the rivets for the rear leaf spring hangers.
I'm thinking that the brackets must be different for long and short bed, as the long bed leaf spring hanger rivets would be a foot or so forward. Stickman - thanks, I'm looking forward to your pics. If it turns out that my truck is different from everyone elses, I'll try to return the new mounting brackets I bought recently, and use the old coil spring mounting brackets to try to fabricate something.
02-11-2013, 04:33 PM | #18 |
HPCGMC
I have one SWB with leaf and one SWB with coils,would it help if I send some pics of both ? If that will help I will be home tomorrow and snap some pics for you of each. Posted via Mobile Device |
02-11-2013, 04:54 PM | #19 |
Stickman - yes, pics of both would be very helpful. Thanks!
02-13-2013, 02:55 PM | #20 |
The leaf and the coil are both the same on my pick ups . Both the inner and outer bracket use the same hole/bolt closest to the bumper. The inner bracket also uses a bolt hole just forward of the cross member. I just tried to upload 4 more and it says a security token is missing ?
