02-05-2013, 04:24 AM | #1 |
gauge cluster lights and fuel gauge
I'm new to the forum and looking for help....I recently just traded for a 78 lwb 2wd that was a diesel and was converted to a 454,the truck is in great shape and ready to drive other than the gauge lights don't work and the fuel gauge does not work for either tank....any suggestions to what I need to try to check,how to diagnose?
Posted via Mobile Device |
02-05-2013, 09:50 AM | #2 |
78K & 79C Jimmys
Re: gauge cluster lights and fuel gauge
there is a spot where the grounds go to one behind the cluster
bout a foot from the plug in it's the grey wire supplying the juice for dimming make sure the copper strips @ the plug are straight gauge up or down? was the cluster changed? up can mean the sender is unhooked
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
02-06-2013, 03:09 AM | #3 | |
02-07-2013, 10:59 AM | #4 | |
78K & 79C Jimmys
nope no power, but if other people added extras in the dash it may have hacked/burned the ground
02-05-2013, 12:27 PM | #5 |
Gauge is stuck all the way passed full and hasn't moved for either tank,Im pretty sure it's the stock cluster from when it was diesel....those wires could be the problem for my gauge lights as well? (Also my lights in my radio and the one by the windshield wiper switch work)
02-05-2013, 04:05 PM | #6 |
78K & 79C Jimmys
if those ones work pull the cluster check the paths
you can see how they bend (i use crazy glue) meter the grey wire for power,should vary when dial turned I'd check the clips in the cluster ,corrosion etc is possible too could do a temp wire to test/bypass the switch and sender
02-06-2013, 12:15 AM | #7 |
Would it just be easier to buy the new cluster?
02-06-2013, 12:17 AM | #8 |
I always check fuses with stuff like that first.
1967 gmc 4x4 factory air factory buckets 1985 gmc high sierra 2500 4x4 400 1972 ford f250 4x4 390.Tomorrow is the most important thing in life. Comes into us very clean. It's perfect when it arrives and puts itself in our hands. It hopes we've learned something from yesterday. John Wayne |
02-06-2013, 01:11 AM | #9 | |
02-06-2013, 01:18 AM | #10 |
I`d say check fuses and if they end up being good then check your your bulbs and printed circuit on the back i had to replace mine and they can burn through in spots easily.if that all seems to be fine then check grounds and wire leads fixing or replacing any that needs to be. If the fuel gauge is reading past full and not moving its most likely a bad ground mine did that and i found a few open spots on the ground and taped em up and it worked like a dream afterwards. if its not a ground problem then check sending unit, make sure its the right for the tank ( I ran into that problem on my dads scottsdale with the float hitting a baffle) you can also check to see if the sending unit is good all you need is a volt meter one with the needle gauge... attach it to where the wires go in and get a good ground and with the float at the bottom it should read o. when you move the sending unit float the needle on the voltmeter will move accordingly. Just set it on the normal 12v reading setting. i imagine a digital one would work but i have never tried with a digital one so i do not know for sure.
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373 1984 Chevy C10 short bed 2001 Chevy Impala police cruiser 2001 Chevy Silverado 1500 Z71 4wd extended cab dd |
02-06-2013, 01:20 AM | #11 |
Here's a link to a diagram. http://static.cargurus.com/images/si...2934815889.gif
02-06-2013, 01:27 AM | #12 |
Is this what you are asking for????
A - Fuse - Traffic Hazard B - Fuse - Tail, Stop Courtesy Lamps C - Receptacle - TP2 /M40 D - Fuse - Radio & TCS F - Receptacle - C91/UF2 (Cargo Area Lamp)/U35/U37 G - Fuse - Heater / Air Cond. H - Receptacle - C62 I - Fuse - Accessory J - Fuse - Panel Lights K - Receptacle - NL2/A33/U16 (Tachometer) M - Receptacle - Accessory Lamps N - Not Used O - Fuse - Reversing Lamps P - Fuse - Instrument Cluster Feed
02-06-2013, 01:54 AM | #13 | |
02-06-2013, 02:20 AM | #14 |
Fuse ratings.
A-15A- Directional Signal Indicator Lamp, Stop Lamp, Traffic Hazard B-20A- Courtesy Lamp, Roof Marker Lamp, License Plate Lamp, Parking Lamp, Side Marker Lamp, Tail Lamp, Clearance Lamp D-15A- Idle Stop Solenoid, Aux. Battery, Radio, Time Delay Relay, Emission Control Solenoid, Transmission Downshift (M40) E-25A- Windshield Wiper/Washer G-20A- Heater, Front A/C, Generator Warning Lamp I-20A- Cigarette Lighter, Clock, Dome Lamp, Cargo Lamp J-4A- Instrument Cluster Lamp, Heater Dial Lamp, Radio Dial Lamp, Cruise Control Lamp, Windshield Wiper Switch Lamp O-15A- Cruise Control. Rear Window Aux., Fuel tank, Tachometer, Back-up Lamp, Directional Signal Indicator Lamp, Directional Signal Lamp, Headlamp Buzzer P-4A- Fuel gauge, Brake Warning Lamp, Temperature Warning Lamp, Oil Pressure Warning Lamp
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
02-06-2013, 11:50 AM | #15 |
im not sure what the panel fuse is, that is just a diagram from a 77 i had saved on my computer from a while back.
02-06-2013, 01:50 AM | #16 |
Yea I know for sure my gauge cluster fuse is good because I changed it......as for the fuel gauge where is the ground wire because the PO told me that its probably a ground wire
02-06-2013, 09:51 AM | #17 |
If your fuel gauge is stuck way past full. Check the wire coming from the tank, it may be grouning at some point between tank and gauges. Mine got against the header pipe and ground out causing the gauge to read way past full and not move.
02-06-2013, 11:54 AM | #18 | |
02-06-2013, 12:30 PM | #19 | |
Moderator
Breaking the sender wire will send the needle to 3:00. I assume the other gauges work..??? Is the (P) PANEL LPS fuse good? Is the (I) CLUSTER FEED fuse good? Turn signal and HI-Beam indicators work? Volt, OIL, & TEMP gauges work? Checking the instrument lights.
Fuel Gauge (see the 1978 NL2 dual tank wiring diagram below or download the whole 1978 GM wiring diagram book in PDF from the thread in my sig) Way past full is usually a bad tank ground or broken sender wire. With dual tanks it could be as simple as bad dash switch. You can test the switch and gauge mostly from inside the cab as follows. You'll need;
Testing the switch. The switch has 3 terminals on one side and two on the other. The fuel gauge is hooked to the common terminal (#4 on the GM NL2 wiring diagram) senders are on terminals #3 & #5. The valve is powered by Terminal #2 from terminal #1. If the switch fails any of these tests replace it.
Testing the gauge and sender wires from the switch plug on 73-80 systems.
Gauge is working checking the senders... NOTE RH & LH tanks... This procedure assumes 1978 AUX tank position. Not all 73-80 AUX tanks are on the LH side.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
02-06-2013, 02:29 PM | #20 | |
02-06-2013, 03:46 PM | #21 |
Moderator
This is specific to the 78 dual tank truck. A single tank would not have a switch in the knee panel of the dash.
02-06-2013, 03:11 PM | #22 |
From experience, burning thru to the wire and grounding on the header will also cause the needle to the three o'clock position. This has happened twice since I bought the truck new in '77.
02-06-2013, 04:09 PM | #23 | |
Moderator
Firmly grounding one of the 73-91 GM fuel gauge sender wires will always drive the needle to E. Unplugging the sender wire or the tank ground (open circuit) will always drive the needle to @ 3:00. Sender wire shorted to ground = E, 90 ohms to ground = F, and Open circuit = 3:00. Been there done that with over 20 73-91 GM trucks.
02-06-2013, 06:51 PM | #24 |
Sorry for using the wrong terminology, the wire had melted thru the casing and stuck to the header. So would this have been an open short?
02-07-2013, 01:12 PM | #25 | |
Moderator
The fuel gauge sender runs from 0Ω E to @90Ω F + or - 3Ω. If the resistance on the sender side rises higher than 90Ω the needle will continue to rise corresponding to the resistance till the needle is pegged at roughly 3:00. I haven't tested the resistance that actually pegs the needle. Probably around 120Ω give or take 2-10Ω . From there to completely open ( ∞ Ω ) the needle will sit pegged at roughly 3:00. If you don't believe me. Get some liquid electrical tape to repair the pinhole you are about to make. Then. Stick a pin through the sender wire and firmly ground it. The gauge will drop to E.
