Hole saw through trailing arm crossmember, safe?
I'm converting to an automatic transmission and would like to run a new exhaust system between the frame rails out to the back of the truck. The front crossmember is no longer a problem since it has been removed altogether.
Do you guys think its okay to punch two 3" holes through the trailing arm crossmember? It wouldn't weaken the crossmember enough to be unsafe would it? If anyone has done this before, pictures would be nice! |
#2 | |
![]() Join Date: Sep 2012
Re: Hole saw through trailing arm crossmember, safe?
Cluster King
![]() Join Date: Nov 2012
The only way I would do it that way is to use a piece of 3 in i.d pipe with 1/8 inch wall thickness about 2 inches wide and weld that in the hole. That would add extra strengh to the crossmember. You will have to punch a 3 1/4 hole in the crossmember. I would use a hole saw for this, so it is nice and clean.
There are already two wide slots stamped into the crossmember that leave that area open so I doubt that cutting it would make it much weaker. I'm going to cut 4" holes, box the open side of the crossmember, and weld 4" pipe through the opening to strengthen the cut.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
I am also curious on this subject as I am going to lower my truck - do you have to then contend with the trailing arms right after you cross through the member?
64 Step Side - The Mistress |
Oh just to clarify, I am NOT running 3" pipes. More like 2" or 2 1/4." My engine doesn't make near enough power for a dual 3" system!
![]() I just thought 3" holes would provide adequate clearance for a 2" pipe and allow it to move some with contacting the crossmember. Thanks for the info and pics so far! I like the idea of restrengthening the hole by welding a short length of pipe into it! |
Hopefully some more people will chime in on this with opinions and pics because I'm thinking about cutting a hole and welding in a peice of pipe in rather to buying one of these http://www.performanceonline.com/196...pension-19834/
![]() Join Date: Mar 2011
It's not going to be any weaker than that aftermarket one and there are many that have done it.
![]() Join Date: Aug 2008
On a street driven truck with stock type powertrain, you'll probably never know the difference.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
There is no problem doing that as long as you weld in a piece of pipe as stated above.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
![]() Join Date: Jun 2014
Any updates on guys punching out the holes with a hole saw? Would 3.5" hole be to big? I am planing on running 3" pipes.
Moderator
![]() ![]() Join Date: Aug 2011
I did the hole cutting thing first. Then mocked up my truck at the position I wanted it, chassis height and all including the drive shaft engine and transmission. Which convinced me to purchase the POL cross member. Buy the way, that thing is "heavy wall" steel, more so than the stock cross member.
Do they make large hole saws for cutting through steel like that? I would think that the cutting edge would need to be sprayed with that carbide looking stuff that you see on sawzall blades.
![]() Join Date: Feb 2016
You would need a torqie drill that's for sure! And some Popeye forearms! I have some 3 - 4 inch wood/metal blades and a magnetic drill press that might work but would rather use a plasma and something Round as a guide
#15 |
Moderator
Take a piece of sheet metal use C-Clamps to clamp it to the back side. This will be used for keeping the hole saw center drill bit in place. Now drill your hole with the hole saw. I did it, worked great.
#16 |
I did it on mine. Then I took 4" steel pipe and welded it in place to add some rigidity back to it.
#17 |
meowMEOWmeowMEOW
One of the beauties of owning heavy, old trucks; you can drill a hole in almost anything and it'll be fine. My trucks gone through 3 engine combos, 3 trans types, and a few suspensions...so almost everything's had a few speed holes in it.
Like the other guys have said, a little reinforcing won't hurt (especially if your near an edge or wanting to "notch" the thing instead of go straight through). That being said, tubular crossmembers are veeery nice.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#18 | |
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
