02-06-2013, 02:03 AM | #1 |
I need a little schooling on manual transmissions
One day, I would like to go 5-6 six speed. What are my options? I need od. Right now the truck has a th400 with 4.11 gears. Its about to be my dd. The motor is pushing 400-500 horse, and it is a small block. When ever I can do this, I'd like to keep it as low budget and simple as possible. From the way i am able to take it, it still has manual peddle assembly, as it use to have a Muncie 4 speed, but my father swaped that over in the early 90s. He just, cut out the clutch peddle.. The main reason I am wanting the swap, is to have it back to a standard shift. Doesnt have to be any close gear ratio or anything special.. Just, something to drive
02-06-2013, 01:25 PM | #2 |
Re: I need a little schooling on manual transmissions
NV4500 out of a 2500 Chevy truck. They are truck transmissions though... But from your horsepower and budget standpoint that's probably best option. Or, like everyone else will suggest, bite the bullet and get a tremec tko right away.
72 C10 - Multicolor, 4.8 ls, NV3500. Sold 72 K5 - Under Construction |
02-06-2013, 01:47 PM | #3 |
NV4500 won't hold up to the torque you are putting out. They used them in Dodge trucks in the 90's and even with a stock engine they were failing. The overdrive gear retaining nut would back off and you would lose 5th gear. There was a redesign on the mainshaft but it didn't fix the problem, the nut would still come loose. I would say TKO or Richmond would be your best option. Not the least expensive option, but if you are pushing 500 hp you will need something that can take it.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-06-2013, 02:04 PM | #4 |
Take a look at Tremec TKO 600 that should work well for you. I'm running that setup in a 500+ HP Cobra
Posted via Mobile Device |
02-06-2013, 02:07 PM | #5 |
ZF6 Black label. They are a bit noisy if you get the early one. They have square cut gears but will handle 500 lb/ft of torque....Ask how I know this.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
02-06-2013, 02:28 PM | #6 |
Proprietor of Dale's Corner
OK... I give up, how do you know
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
02-06-2013, 02:34 PM | #7 |
there is no budget friendly way to get a 5-6 speed manual for these unless you go for the nv4500 or t5, but those won't handle the power you have unless you baby it.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
02-06-2013, 04:46 PM | #8 |
From ZF's web site:
Transmission type: S 6-650 Input torque max.: 720 Nm (Ft. Lbs. 520) (Reference value: depending on vehicle data and application conditions) Standard ratios Gear: 1: 5.79 2: 3.30 3: 2.10 4: 1.31 5: 1.00 6: 0.72 R: 5.23 Weight without auxiliary: 106.5kg (235 lbs) Oil quantity: 6.0dm3 (5.8 Qts.) Oil grade as per ZF List of Lubricants: TE-ML 02; specification acc. to vehicle manufacturers instructions Installation Longitudinal with shift output for left or right-hand drive vehicles These units have a smaller gear set for gas engines so the ft/lbs rating is probably closer to 450 on gassers. Also, from what I've read about these ZF transmission, there is usually a 20% safety margin built in to them so they could handle 624 ft/lbs.
02-06-2013, 04:51 PM | #9 |
t-56 is probably still cheaper than that and parts are everywhere
02-06-2013, 05:15 PM | #10 |
The ZF-6's were used behind the Duramax diesels.
02-06-2013, 05:16 PM | #11 |
they were also used in corvette c4's though
02-06-2013, 05:40 PM | #12 |
The Corvette ones are a little different. They have 2 overdrive gears, 5 and 6. The ZF6-650 has only one.
Billet you are right. I guess I missed the part about "low budget".
02-06-2013, 06:16 PM | #13 |
not a big deal. I wish it were cheap though. I want to do the same thing, but I've resigned myself to saving up for the tko or t56 magnum. I'm also considering the 6l80 simply because many of them come with lq4's attached
02-06-2013, 07:07 PM | #14 |
Some things come to mind here. First the motor numbers seem to be a WAG based on previous posts. Second the truck is drivable now so maybe a gear/axle swap might be the best initial step for a sixteen year old. If he does want a manual, what parts does he have left? Was the truck originally a manual or automatic truck? Does it still have the bell housing crossmember or clutch z-bar and linkage? Maybe a MY6 or MM7 four speed O/D would be a good choice that someone has laying around.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-07-2013, 11:41 PM | #15 |
Earlier I had mentioned using the MY6 or MM7 if he can find one. It seems to me it is a good compromise. The 80ish Dodge pickup I remember driving had one and it did well.
02-06-2013, 08:34 PM | #16 |
Didn't realize he was 16. Keep the th400 and the 4.11s, it'll keep you out of trouble.
02-06-2013, 09:35 PM | #17 | ||
Having said that, however - I agree, 5or6speed + 500hp = not on a budget |
02-06-2013, 09:28 PM | #18 |
Thanks everyone for the input.
And who cares if I'm 16? Really?lol Kinda, funny... Always brought up. If you knew my past in driving, you'd no I am responsible. But, hey. This is society today. I'm told by everyone I drive like an old man. I have Looked a little more into things, and I am a slow driver. So I'll probably save for a tremec tko500 and just do it right. Posted via Mobile Device |
02-06-2013, 11:41 PM | #19 | |
02-07-2013, 12:42 AM | #20 | |||
Also, was originally 3 on the tree v8 truck. |
02-06-2013, 09:41 PM | #21 |
Also take a look at the Richmond 6 speed I love my 5 speed but it's not a true od like a 6.
02-07-2013, 02:19 AM | #22 |
3 on the tree would be great for nostalgia, but not so much for a DD. I run a 4 speed NP435 with a granny low. Once you get used to not having overdrive it really isn't terrible and I drive it for an hour at a time on the highway on my way back and forth to work. Check out this calculator. You can plug in your ratios and tire size to figure out what rpm you will be running at, just to make sure you don't push the engine too hard. If you click on the frame that says "calc" on the bottom it will come up with an empty table that you can fill in with a possible 6 gears. The numbers shown in this one are from my truck.
http://xse.com/leres/bin/gearratio?t...le=60&wheel=15
02-07-2013, 02:33 AM | #23 |
Thanks for the calculator, what mpg are you averaging? Also, we have two 3 speeds that are manuals. I do not know a thing about them. I've considered one of those. If they have the same final gear and everything, I may just use those. I'm sure they need fully gone through. I just would like a third pedal lol Ill try and pull some numbers tomorrow
02-07-2013, 01:53 PM | #24 | |
I'd rather do a 5 or 6 speed and have the overdrive, but the 4- speed was free.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
02-07-2013, 11:16 PM | #25 | ||
