Old 06-13-2003, 12:09 AM   #1
da-burb
"Ochre Ogre"
da-burb's Avatar
Is there a correct propeller shaft alignment?
I would assume that there is a right and wrong alignment on the front drive shaft. Looking at the constant velocity U-joint, if the front yoke on the drive shaft is horizontal, I am thinking that the other end at the slip shaft should be horizontal also. I looked under my other 4x4's and 2 were 90 degrees off and one was as I described. What say the experienced 4x4 gurus. (or doesn't it matter at all)
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 06-13-2003, 07:56 AM   #2
Blazer1970
Blazer1970's Avatar
On a shaft with a double cardan joint at the t-case, it does not matter what the orientation of the other end (u-joint at axle) is.
Blazer1970 is offline   Reply With Quote
Old 06-13-2003, 08:18 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
What Tim said. Also the angle at the u-joint end should be as close as possible to zero degrees.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-13-2003, 08:23 AM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
Thanks!
Old 06-14-2003, 12:53 AM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
Ok, now inside this double cardon joint is a spring. What is it's purpose? Because it sure doesn't look like it does much of anything.........
