02-09-2013, 01:02 AM | #1 |
A couple ?s
Are the E-brake cables the same as the trucks, I need the 2 rear cables that goes to the rear brakes. The cable out of the cab looks good. But I should just replace them all? This is for my 63 Burb.
Also for the Burb I need the steel body mount piece on the side of the cab. Where the rubber from the frame meets the body, I'll try to get a pic up in a few minutes. Anyone making these mounts? My right side is in pretty bad shape. Posted via Mobile Device OK, here is the picture. I need the metal piece on the left side in the picture. Thanks Capt. that's what I afraid of.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 Last edited by MikeS.; 02-09-2013 at 01:33 AM. |
02-09-2013, 01:09 AM | #2 | |
60-66 Nut
Re: A couple ?s
The e-brake cables will be the same as for a '63-'65 shortbed truck.
The front cab mount is the same as for a pickup. Everything from the B pillar back is Burb/Panel specific. I do not know of anyone reproduicing these. Quote:
