Old 02-09-2013, 04:57 PM   #1
1972K20
1972K20's Avatar
U-Joint Removal
Hey guys, how do you remove this cap? Aren't the clips under this cap?
1972K20 is offline   Reply With Quote
Old 02-09-2013, 05:05 PM   #2
76k10
Re: U-Joint Removal
Take it to a drive line shop and have them replace that U-Joint. Trust me. Unless you have the proper press and experience to change them, you will end up just wasting a bunch of time and/or ruin your shafts. Stock u-joints in old shafts are usually stuck in there very well.
76k10 is offline   Reply With Quote
Old 02-13-2013, 08:07 PM   #3
Redcap
Re: U-Joint Removal
Originally Posted by 76k10 View Post
take it to a drive line shop and have them replace that u-joint. Trust me. Unless you have the proper press and experience to change them, you will end up just wasting a bunch of time and/or ruin your shafts. Stock u-joints in old shafts are usually stuck in there very well.
lol wut
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 02-20-2013, 01:33 PM   #4
RastaRobb
RastaRobb's Avatar
Re: U-Joint Removal
I'm with the other guys, you can do it, and if your going to spend your life with Chevy trucks, you will do a lot of them. A little penetrating oil will help. Old sockets were mentioned--you want one that is just smaller than the hole of the yoke, to place on the end of the joint, then pound the fire out of it.
RastaRobb is offline   Reply With Quote
Old 02-20-2013, 01:37 PM   #5
RastaRobb
RastaRobb's Avatar
Re: U-Joint Removal
I've even cut a particularly difficult one out with a really thin cut-off grinding wheel. Don't recommend that, but it did get the job done.
Old 02-20-2013, 07:35 PM   #6
76k10
Re: U-Joint Removal
Yeah, you will do a lot of them because you hammered the crap out of them and distorted the yokes. Enjoy when those new U-Joint caps pop out. $30 at a shop, no hassle, no pounding sockets, no ruined axles. To each his own, I'd rather be riding than messing with a front end because I though I could do it myself because everyone said it was easy.
Old 02-20-2013, 08:21 PM   #7
odog
odog's Avatar
Re: U-Joint Removal
I've done a few, pretty easy you can use a good vise and some penetrating oil and they should pop out. And uh, I have NEVER distorted a yolk or had caps pop out. I've even used a high and a socket, never distorted or ruined an axle. But to each his own, some of us like doing things on our own. Personally I hate bringing anything to a shop.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 02-09-2013, 05:08 PM   #8
1972K20
1972K20's Avatar
Re: U-Joint Removal
Ok, but I'm curious, doesn't that cap+clips have to come off before the joint can be pressed out?
Old 02-09-2013, 05:16 PM   #9
Crash_OK
Crash_OK's Avatar
Re: U-Joint Removal
Yes on the inside of the caps..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 02-10-2013, 05:13 PM   #10
Transformula
Transformula's Avatar
Re: U-Joint Removal
Look on the inside of the yokes. there will be c-shaped clips in there that need to be removed first. You will probably have to clean up the area first to see them. straddle the opposite yoke across something and press out the u-joint caps. A new u-joint will come with new clips, and some brands even have a female grease fitting on the outside of one cap so you can grease it. If not, add lots of red grease before reassembly. That will also help hold the needle bearings in place! It's a piece of cake!
T.Y.N Custom Works..... Because "Stock" Sucks!
1971 K 10 GMC Long Bed
1977 Formula T/A Frame off Resto-Mod
1995 FXDL Harley Low Rider
1985 C10 ShortWide 91 Burb front.
Transformula is offline   Reply With Quote
Old 02-13-2013, 05:44 PM   #11
willett
Another Day, Another Dollar
willett's Avatar
Re: U-Joint Removal
You need minimal tools to do u joints:
Dead blow hammer
Vice
Old sockets
Pliers for the clips
There isn't really much to it and you certainly don't need to pay somebody to do it for you
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 02-20-2013, 01:39 PM   #12
RastaRobb
RastaRobb's Avatar
Re: U-Joint Removal
Once they are out, you will want to clean up the inside of the yoke with a really fine sand paper before putting the new one in. You can do it.
Old 02-20-2013, 03:21 PM   #13
willett
willett's Avatar
Re: U-Joint Removal
You get em out?
Old 02-20-2013, 08:56 PM   #14
kenbob87
kenbob87's Avatar
Re: U-Joint Removal
ive always done my own u-joints and never have i ruined or distorted a yoke... even on my alum driveshift in my 02 chev... i always hammer them out and use a vise and sockets to press the new caps in. in my opion u-joints are very simple to do with very minimal tools
kenbob87 is offline   Reply With Quote
Old 02-20-2013, 09:12 PM   #15
Rubble
Re: U-Joint Removal
U joints are funny,some guys won't go near them,Been replacing them close to 30 years,don't think I ever wrecked one & had a few outta round ones and still got it together.Like others said,BF hammer,vise and I usually use a nut just smaller than the cap,works really good.Besides if your out in the bush & need to replace a joint,that machine shop won't do you much good....it's better you learn how yourself...
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 02-21-2013, 01:15 AM   #16
1972K20
1972K20's Avatar
Re: U-Joint Removal
Thanks guys. I played it safe and had a machine shop do it. It was inexpensive and very quick. I watched the guy do it, so I'll know how in the future. It would have taken me much longer without the press that he used.
Old 02-21-2013, 01:40 AM   #17
kenbob87
kenbob87's Avatar
Re: U-Joint Removal
nothin wrong with playing it safe! the very first u-joint i replaced when i was 15 i destroyed 2 of them before i got it right all the needle bearings kept falling over as i was trying to pound the new caps on lol after i finally got it figured out my step dad informed me of doin it the right way with the vise he said he wanted me to learn the hard way first lol
but glad you got it taken care of and now know how to do it
