tire size how wide
how wide and tall of a tire can i use on the rear of my truck using stock 4x4 rims? trying to go for an ole school hotrod look.
Victory will only be achieved through superior firepower and trusting in the Lord. SOLD 68 C-10. http://67-72chevytrucks.com/vboard/s...d.php?t=560975 SOLD 2000 Silverado...http://67-72chevytrucks.com/vboard/s...=1#post6492671 87 V-10 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=643898 |
Re: tire size how wide
Tire width is dependent on rim width, 10'' wide rims from a 4x4 can use a 275/60 /15 with no problems and will fit . also stated tire size is 28'' tall.
255/70/15 looks pretty good.
=MATTHEW 69 Stepper...Stroked & Bagged ![]() 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
I've got 275-60-15's on mine all the way around.
Posted via Mobile Device |
285/70/15 on the rear 235/70/15 on the front if you want the old school look. The 285/70/15's are only available from Coker Tire, so if they're too pricey, you can always run a 255/70/15.
My rims are said to have come off of a 73 4X4, they are only a tad wider than the stock 67- 72 rims. I was hoping to use a 60 series tire for the rear, but just not sure if the rims are wide enough. I am guess that they may be 7 inches wide.
I have my 255's on a 7" wide rim. Do you want your tires the same all the way around, so you can rotate 'em and such, or do you want wider in the rear for a staggered look? You could go with 255's all around, or 235 front/255 rear, 255front/275 rear...the options are knida endless, it all depends on what you want!
Going wider in the back, probably 235's up front, they are easy to find for the cheap......
