Old 02-11-2013, 11:54 AM   #1
McKenna
Can someone check my homework
I have a complete LQ4 with no transmission
I have a line on a 65'000km 4L60e for 250$
I am Likly going to go this route and build the transmission as I need it.
I will need the flex plate, torque converter, transmission, starter
And pigtail for wiring harness as the one that came on my lQ4 is a 11 wire
And the 4l60e is 13.
Can anyone chime in and tell me if I should get anything else off of this donor truck to make my swap easier, it'll be cheaper to get it all at once then buy it in pieces after.
Does the 4L60e just run off of the lq4 Computer or do I have to get another computer while I'm getting this transmission.
As well I am currently a 4 speed manual, do I need the column or shifter linkages or anything??
Thanks in advance guys I had planned to go T56 but money just isn't going to allow it so this seems like my best bet
McKenna is offline   Reply With Quote
Old 02-11-2013, 11:56 AM   #2
McKenna
Re: Can someone check my homework
Both engine and trans are 04 so I should just have to remove my flex plate and spacer and then install the 4l60e flex plate off of the 4.8l???
Old 02-11-2013, 12:56 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Not every lq4 had a 4l80 behind it, in 04 the lq4 would have the "normal" or "short" crank, which will work with either a 4l80 or 4l60...99-00 lq4's had a long crank snout and only work with the 4l80.
The computer will run the trans, but you'll need to have the pcm tuned anyway to remove VATS and emissions, EVAP etc.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-11-2013, 01:03 PM   #4
OldCreek
OldCreek's Avatar
If its drive by wire, be sure to get the pedal, tac module and their wiring.
You'll use a different shifter and cable.
You might want the gas tank/pump module...depending on what you're doing.
You might want the gauge cluster...depending on what you're doing.
Stock radiator hoses may work for you, also. As well as the fan clutch/fan...depeding on what you're doing.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-11-2013, 01:09 PM   #5
McKenna
I already have the complete Lq4 with all accessories PCM and harness, just Been hunting for a trans when this 4l60e popped up
