Block and suffix codes
The block is a 3970010 which I know is a 350 and has an 84 stamped close to that. The only question I have is that the only suffix code stamped on the front deck I can tell is 1K09800. Any ideas on that? The vin shows the truck to have came w/ a 305 so I'm wondering if its a crate motor
71 c10 swb |
Re: Block and suffix codes
0010 means its a 4 bolt main thats good, and i know that front number is the one they use like in restoring cars to see if its a number matching car
'82 c10 shortbed drag truck '82 GMC 3500 Dually DD scrap truck '55 Chevy 210 4 door sled '65 VW Bug Rat Rod |
78K & 79C Jimmys
not sure about crate but
I've been told it's a desired "nickel block" i think mine was from a pre 78 - 3/4 ton but yes it's a 4 bolt
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
![]() Join Date: Oct 2009
SBC 3970010 can be 302 or 350 blocks and came in 2 & 4 bolt mains. If you ever find a 010 block with DZ in the suffix that is a 69 Z28 302 block. On your suffix, the K meens Canada plant. The 09 meens September. The rest of the suffix stumped me, cant figure it out.
010 just means high nickel block, not 4 bolt main i have seen many 2 blots cast in 010
#6 | |
78K & 79C Jimmys
rereading that sounds like i'm sayin they "all" are i've had my pan off so i know
the only way to know for sure without taking the pan off is to look at the stamping on it, on big blocks it in the front by the bottom of the drivers side head, not sure where to small blocks is
