Old 02-12-2013, 01:18 PM   #1
78f1hundo
Cowl screw size?
Well my project truck is missing these and need to go pick some up. Any one know the size I need?
Thanks,
Steve
65' Chevy C-10 Shortbox
78f1hundo is offline   Reply With Quote
Old 02-12-2013, 03:38 PM   #2
DURG
DURG's Avatar
Re: Cowl screw size?
Thinking you will be asked to provide a little more info before you get help...
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 02-12-2013, 04:15 PM   #3
78f1hundo
The upper cowl corners need 4 screws or bolts to hold them to the cab. Need to know what size? 5/16's? 1/4's?
Old 02-12-2013, 07:38 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
not sure the size but you can find them all over the front clip, they are the ones that take the 1/2 inch wrench, and look the same as the ones that hold the fender to the inner fender and the inner fender to the core/grille support. they also used shims to adjust the cowl corners to the hood and doors.
Old 02-12-2013, 08:26 PM   #5
78f1hundo
Thanks, that helps.
Old 02-12-2013, 09:40 PM   #6
DURG
DURG's Avatar
5/16-18 by about 3/4" if they take the 1/2" socket.
