02-12-2013, 06:06 PM | #1 |
Do I Have To Get New Wheels??
I am in the process of completing a disc brake upgrade to the front wheels
of my 69 C-10 P/U. I've heard that I may have to have new wheels due to possible interference issues with my old rally wheels. Anybody have any experience in this regard? Jim |
02-12-2013, 06:12 PM | #2 |
Re: Do I Have To Get New Wheels??
Rally wheels were used on later trucks and didn't come on 67-72's so chances are that the backspace is sufficient for caliper clearance. 4" backspace should work.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
02-12-2013, 06:16 PM | #3 |
i have 15" corvette style rallye wheels on mine with front disc brakes and no clearance problens
02-12-2013, 07:27 PM | #4 |
So you're converting from 6 lug to 5 lug correct?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
02-12-2013, 08:33 PM | #5 | |
Usually?...really?
I would love to know when it is desirable....
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
02-12-2013, 09:26 PM | #6 |
6 lug steelies (original wheels) are not disk brake compatible - the taper on the inside face is canted and interferes with the caliper. It's not necessarily a backspacing issue.
Are you using truck or car rallies? (i.e. are you retaining 6 lug or converting/converted to 5, etc). Reason I ask - I can't confirm for you that old vette rallies will clear, but all truck rallies will clear (stock size disk + caliper combo). But, truck rallies are 6 lug, car rallies are 5 lug. You mention your old rallies - they are definitely newer than your truck, and rallies do fit with disk brakes, assuming you're going with a stock-size rotor, etc. BIG brake kits will not fill rallies. But, if you're buying a kit for stock size application, rallies will be fine. |
02-12-2013, 09:42 PM | #7 |
My dad's '69 has a stock '72 front disc setup with 15x8 corvette rallys and they fit fine. Not sure what route you're going...
02-12-2013, 10:06 PM | #8 |
I bought the truck in May of 02 and it had the "rallys" on it then. I'm keeping the 6 lug configuration. I guess the only way to tell is to bolt 'em on and see.
Will let you know what I find out. Jim |
02-12-2013, 11:30 PM | #9 |
Mine did not fit,when i changed to disc, brakes i had the rim changed. the cut it out and they used my old centers.
and when they do this you can get them right where you want them. as back spacing just dont use pico wheel he is a pain in the A.
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
02-12-2013, 11:31 PM | #10 |
post pictures of your rims now front and back, let me see what you got
02-12-2013, 11:35 PM | #11 |
I put on Rally's after I did a disc brake swap and didn't have any issues. I've heard that the 15x8's come really close and sometimes hit the lower control arm when you turn. Mine are 15x7 and I don't have any clearance issues, caliper or control arm.
02-12-2013, 11:38 PM | #12 |
my 15x8 are close to my tie rod knuckle ....way close
