oil change ?
any one have any idea are suggestions .. what kind of oil ? weight ? brand ? Filter ? i should be using
1969 C20 CUSTOM "RUMBLEr" |
Re: oil change ?
Vavoline VR1 30 OR 40 WT Racing oil.
Re: oil change ?
Well the filter i would highly recommend WIX, the oil depends on if you need zinc in the engine or your just looking for a good oil with no zinc, weight 10w30 or 10w40
i use brad penn 10w30 in mine, kendall or amalie oil is good, i use amalie in my 2011 silverado. What kind of engine do you have, is it daily driver or weekend warrior? |
#4 | |
Re: oil change ?
Re: oil change ?
its just a reg 350 btw
thanks ! ..
Re: oil change ?
i would get a good 10w30 and a wix filter, you'll be fine
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: oil change ?
Agreed. If you're near a NAPA store, their oil is made by Valvoline and their Gold line filters are made by Wix.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Oct 2009
Re: oil change ?
i'm a Valvoline Conventional 10W30 and Fram PH30 filter kinda guy myself.
Re: oil change ?
Re: oil change ?
Re: oil change ?
I prefer full synthetic oil in my vehicles.
Posted via Mobile Device |
Re: oil change ?
Ive been using the ph5 for last 12 years on my 350.I may be using the wrong one.Lol.I thought the ph30 may be a heavy duty filter that held more oil.
Re: oil change ?
The Fram PH5 has an anti-drain back valve in it, the 30 does not.
T.Y.N Custom Works..... Because "Stock" Sucks! 1971 K 10 GMC Long Bed 1977 Formula T/A Frame off Resto-Mod ![]() 1995 FXDL Harley Low Rider 1985 C10 ShortWide 91 Burb front. |
#14 | ||
"I ain't nobody, dork."
Re: oil change ?
Fram filters suck... period. Wix or AC. Any 10W30 oil will do.
Gary
#15 |
![]() Join Date: Aug 2010
Re: oil change ?
Wix all the way... I know some guys runs Rotella 15W-40 diesel oil due to the high(er) zinc content... Have used it in a few old trucks and seems to work good.
- 2010 Silverado - 1984 Chevy M1028 (K-30) - 1969 Chevy C-30 - 1933 Ford Stock Car |
#16 | |||
Re: oil change ?
Gary
#17 |
Re: oil change ?
i know im a little crazy but i prefer royal purple in everything i drive, 10 30 full synthetic all the way, maybe a filter to match or k&n
#18 |
Re: oil change ?
?? Anyone ever use k&n oil filters anyone?
72 GMC super custom. ![]() |
#19 |
![]() Join Date: Oct 2012
Re: oil change ?
ive been using the k&n filter on my truck with no issues, i run valvoline 10 40 with two bottles of ca159, i use two bottles because it has an 8 qt pan, but the wix filters are really good, fram filters arent real reliable, to much in my motor to run a cheap filter
#20 |
Re: oil change ?
Wix or AC filter, and 10w-30, usually the O'Reilly Synthetic. I did use some old (unused) Pennzoil my dad gave me, just to get rid of it.
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
#21 |
Re: oil change ?
Wix filters are superior to Fram filters. I was a Fram guy for years until I actually took both of them apart. Now I'm a Wix guy. Seeing as how you are in LA you probably dont need to worry about temperature, temps arent that bad down there. If the 350 has less than 75000 i'd use 10w30, if more than that I'd go 10w40. If the engine is tired and loose i'd go 20w50. I've always had good luck with Valvoline convential oil, no need for full synthetic.
just my .02 cents....
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '24 GMC CC 4x4 Duramax Dually |
#22 |
Re: oil change ?
WIX filter (NAPA Gold is Wix and Car Quest filters used to be Wix and maybe still are.)
15w-40 NAPA oil is Valvoline and 15w-40 is on sale for $9.99/gal until 2/25 |
#23 |
Re: oil change ?
My friend has a mom and pop auto parts store and had a display some years back and it had a wix filter a fram filter and a ac delco filter cut apart and if you seen that you would never use a fram or delco again, if he still has it i will take a pic and post it then you can see for yourself
#24 | |
Re: oil change ?
Chevy GMC Trucks Find Of The Day https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com |
#25 |
Re: oil change ?
