Old 02-14-2013, 03:41 PM   #1
Greenlee
Greenlee's Avatar
Electrical Gurus - Power Window and Lock issues
I posted this a few days ago, but I think my post was so unclear I may as well start over.
I am finishing up the restoration of my 87’ chevy. I used the wiring harness from an 89’ Suburban for the TBI, computer and just about everything else. Everything has been easy, plug and play, until I got to the windows and locks. Where the door harness split off to go to the rear doors, I just cut it off thinking the front doors are independent from the rear doors. For the driver door, I plugged a driver door harness from a truck into the Suburban harness because the Suburban door harness had a gang of 4 window switches and the truck only has 2 window switches.
My symptoms are as follows:
1) Both windows work from the driver side switch, but the passenger side window goes down when you push the button up and it goes up when you push the button down. The switches are ganged together and it only plugs in one way, so the switch is not upside down. I tried two different switches and they behave the same way. I checked the wires going to the motors and they are plugged in the right way. The passenger side motor was a rebuild I believe, so I guess it’s possible some wire were crossed inside when it was rebuilt???
2) None of the switches work on the passenger side. I have tried two different passenger side window switches and various lock switches. Chances are at least some of my used switches are good.
The mess of wires going to the rear doors has a few that are the same colors. I am beginning to think the wires must return from the rear to the front, and I have cut a link in the chain that operates the switches. I have a wiring diagram, but not sure I’m smart enough to read the darn thing. It looks like a tan wire runs between all the switches and there are two tan wires in the ones that I cut going to the rear.
I am wondering if I need to start over with a wire harness from a 2 door, or if I can piece this one back together? Or maybe I have some other problem? Even if I broke a link between the switches, it doesn’t seem like that would cause the passenger window to operate backwards. Below is a picture of the wiring diagram.
I hope someone smarter than I am about this stuff can help me figure this out! I looked at buying a multimeter at Autozone to see if I can test some wires, but that looks more complicated than the wiring diagram.
Greenlee is offline   Reply With Quote
Old 02-14-2013, 06:13 PM   #2
mrhino
Re: Electrical Gurus - Power Window and Lock issues
Im not sure I can help you but, I just converted mine to power windows and locks. Mine didnt run backwards or anything but. when i first wired them I couldn't figure out why only my driver side window would work. it wasn't till all the switch were plugged in before it would work. With that said, I'm thinking they all tied in together. cut the harness may be your problem.
mrhino is offline   Reply With Quote
Old 02-14-2013, 07:23 PM   #3
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
Just to trouble shoot, do you still have the door harness from the suburban? I'm wondering that although the connectors look the same in your drivers door, if some of the wires in the connectors go to different places or are in different locations.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 02-14-2013, 08:49 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
my 87 burb had power locks and crank windows
plugs and colours were the same, just different spots in the plug
i found two close shots
87 no
88 unplugged
89 plugged in...may help
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-05-2013, 11:12 PM   #5
Greenlee
Greenlee's Avatar
I'm getting close on this. I swear the widows and locks have been the biggest pain of this rebuild!
I replaced the Suburban harness with a truck harness and that fixed most of my problems. I figured out the lock relays apparently need to be screwed to the body for a ground, because I screwed the bracket down and the locks started working. I also had to replace both lock switches. I had a mess of old switches but none of them worked in both directions. I guess after 30 years they wear out.
My last problem is the passenger side window switch. It only works in one direction. Sometimes it only moves the window up, other times it only moves the window down. It's not the switch. I have a new switch, and several used switches and they all behave the same way. Any one have any ideas? I figure I must have a bad wire somewhere, but I'm not sure how to test it.
Old 06-06-2013, 07:25 AM   #6
wraprail
wraprail's Avatar
I'm just suprised you still haven't fixed it after 4 months but lets give it a try..
Now the passenger window switch only works in one direction BUT...
sometimes it only moves up and other times it only moves down???
Up and Down.....TWO directions?
Hmmm....
I'm gona guess that if you replaced the window harness with a 2 door truck harness and you did not cut it up or molest it in any way, The wiring is not your problem. If not cut they rarely go bad.
Fugure which way they work and maybe we can help.
wraprail is offline   Reply With Quote
Old 06-06-2013, 08:29 AM   #7
Greenlee
Greenlee's Avatar
Ha,ha. I haven't worked on the windows continuously for 4 months. The truck was taken down to the frame and I have been putting her back together. When I get frustrated with something like the windows, I move on to another project like the bed for a while. here is my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=425848
The passenger window goes up and down like it is supposed to from the driver switch. From the passenger switch it will only goes one direction at a time. Last weekend I was messing with it and it would only go up. Yesterday I was trying out my brand new switch and it would only go down. I'm not sure what I'm doing that changes the direction.
Old 06-06-2013, 01:10 AM   #8
1981Stepside
1981Stepside's Avatar
Does the pass. window work in reverse from the drivers side gang switch?
I read on another power window post that some replacement window motors (forgot which years) have the motor windings in the opposite direction so the wiring is reversed on the plug. As far as the intermittent operation, unplug the harness from the window motor and try using a multimeter (or at least a test light) to see if you're getting voltage on the harness. If so, it's the motor that's gone sour. If not, start tracing backwards up the wiring in the door to the switch.
Are you popping fuses?
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
