Cannot get header to seal!!!
Howdy guys,
I've been through 2 gaskets on the passenger side!! right from the start up they putt and leak out the bottom. The second time I did my absolute best to center it and tighten the bolts evenly from inside/out ( I hate that heater core by the way!!!) any ideas?
-Bruton 1968 GMC long bed 5.7/700R4 --I'd rather push a Chevy, than drive a Ford.-- |
Re: Cannot get header to seal!!!
Have you tried those copper header gaskets.
Is you exhaust binding up and not allowing the header to set on the head correctly Posted via Mobile Device |
Throw away the gaskets. Get a tube of the black RTV. cleans both well no oil. Put the rtv about an 1/8 " bead all around be liberal. Let it set for 3 or 4 minutes each side and bolt it up. Some even put it on the bolts but doubt it is necessary unless they get loose on you. Also recommend you retorgue them after a short drive or in a week or so. Tryed the gasket thing and this works. Haven't seen it fail yet. Good luck
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#4 | |
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
we use ultra cooper when it sets up you cant pry it off
take a straight edge ands see if the header is flat you might have to resurface the header to make flat. i had one that would not seal and i put on belt sander to make flat.
![]() Join Date: Dec 2011
Iave always had good luck with paper gaskets. Soak them in water overnight and install them wet. As soon as you getthem torqued, take the truck for a drive and get it up to operating temperature. The heat will dry the gaskets quickly and help them seal.
use 2 gaskets
454 MAKES IT ROAR
You tell that heater core who's boss brother....
![]() Seriously though...is the header unbolted from the collector? it can put a little bit of a twist on the header making it not seat properly, not much! but thats all it takes. Just a thought.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Set of these bolts might help to so they don't back out Posted via Mobile Device
72 GMC super custom. ![]() |
Remflex gaskets. They work great no trick to putting them on and comes right apart when you need it to.
![]() Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
![]() 1972 gmc k2500 ochra & white (best colors ever)i like them 1971 gmc crew cab (in progress) 1985 toyota ext pickup trail rig (cat yellow) 2009 rzr |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I use copper gaskets top and bottom and not leaks..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
