02-14-2013, 09:02 PM | #1 |
s10 frame and running gear
Has anyone put an s10 frame and all running gear under a 56 chevy pu. Thanks Rich
02-18-2013, 06:06 AM | #2 |
Re: s10 frame and running gear
I'm sure people have done it if your looking for a kit no one makes it for a s10 frame.But there is a frame swap kits for a gm b body and 73-87 gm pickup frame http://www.e-zchassisswaps.com/1955.htm
02-18-2013, 08:29 PM | #3 |
Thanks Andrew good info on that site. Rich
02-19-2013, 03:36 AM | #4 |
Are you trying to a build a 4x4 truck?
02-19-2013, 09:31 AM | #5 |
I haven't decided yet. But if I do I want to go with an indepent sus. Rich
02-20-2013, 07:33 AM | #6 |
I did some digging a found some guys used the 88-98 truck frame http://67-72chevytrucks.com/vboard/s...d.php?t=427550
02-20-2013, 11:37 AM | #7 |
Looks like several options. Thanks for the link. Rich
02-21-2013, 02:23 AM | #8 |
Its not a bolt in but i would trust a 1/2 ton frame and drive train over a s10s.And the 88-98 will give you you the ifs 4x4 you want also.
02-21-2013, 11:48 AM | #9 |
S10 running gear is weak under an S10, let alone a fullsize truck.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
02-21-2013, 12:19 PM | #10 |
Thanks Guys I appreciate the info. I have been in the closet for the last 20 years. Rich
02-22-2013, 03:53 AM | #11 |
He has a point most off road s10s i have seen run full size truck axles.
02-22-2013, 11:38 PM | #12 |
the track width is better for a 4x4 with the s10,, but they are weaker, I'm going with the s10 4x4 when I swap over,, the front track width is almost the same as stock..but if you want ifs and not 4x4,, just do the mustangII..frams are about the same width also..good luck
