02-16-2013, 01:06 AM | #1 |
Rear Main ?
I am working on a 2000 Tahoe 4WD with a 5.3L. 135K Miles. It looks like I will be replacing the rear main seal and the oil pan gasket. Does the rear main seal require any special tools to install ? Or just pry out and tap in new seal ? Thanks in advance
72 C20 Longbed 05 1500 Z71 |
02-16-2013, 12:04 PM | #2 |
Re: Rear Main ?
you should use tool # j 41470 to install the seal properly.
02-16-2013, 10:26 PM | #3 |
Re: Rear Main ?
Thanks ! That must be a GM Special service tool ? Unfortunately I didnt get that far today. I got tied up with other work... I had a heck of a time getting the studs on the tranny though 4wd Tahoes are fun to work on
02-17-2013, 12:25 AM | #4 |
Re: Rear Main ?
I dont know why Im thinking about this right now since Im off of work... but would it be easier to remove the torsion bars & crossmember or remove the transfer case off the tranny to do the rear main seal ? I think Ive drunk too much tonight I always forget about work once I leave
02-17-2013, 10:40 AM | #5 |
Re: Rear Main ?
take the transfer case off of the trans.leave the bars in place.
