02-16-2013, 05:09 PM | #1 |
Need 68-72 Aluminum radiator
needs to have a transmission cooler for a 2WD V8 motor
Can anyone tell me what radiator will work, not sure what size to get. Any websites or part numbers from places like Summit, etc would be a big help in finding a radiator that will work for my 70 rebuild. Thanks |
02-16-2013, 05:58 PM | #2 |
Re: Need 68-72 Aluminum radiator
Welcome the the board, wow three year member and one post. Anyway, not enough info to make a good recommendation.
Not sure what your plans are for engine size or power goals but if you have a stock to street/strip build then a $200 four core radiator from your local auto parts store will be more than adequate. Now if you plan on pushing a billion ponies or need to see that shiny aluminum radiator under the hood that's different story.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-16-2013, 06:08 PM | #3 |
We carry the champion radiators which are an affordable aluminum radiator. They come in 2,3 & 4 row configurations, with an integrated trans cooler. Like mentioned above, is will depend on the engine and HP, to choose which is best for you. Typically a 3-row fits the bill most cases, but again, it all depends.
http://www.azproperformance.com/Cham...369-MC369.html |
10-27-2015, 10:25 AM | #4 | |
thx, D'
1967 C10 SWB Owner - Rustbelt Restorations |
02-16-2013, 06:58 PM | #5 |
Thank you both for your help on this.... yes three year member and only one post :-) ... I joined here before I started my rebuild so I could use these posts and learn what I could before I started.... these forums are a great place to find answers about things other people have had issues with so I can avoid running into the same issues
02-16-2013, 09:15 PM | #6 |
Hey toddnshelly ...
to the forums and from Ohio
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
02-16-2013, 10:21 PM | #7 | ||
"I ain't nobody, dork."
I have an aluminum "ebay special" 2 row radiator in my '72 GMC. Been in there for 6 years with a pretty snotty 355 in it. No problems to date.
Gary
02-16-2013, 10:36 PM | #8 |
If you want to really get a nice radiator, go with a Aluminum 2row Triple pass. You can always go with one without trans cooler build into it and get a race radiator, extend your trans lines via flex under the core support and mount a heavy duty trans cooler on the front of you radiator. Not the cheapest, but I am pushing 430HP Vortec 350 to the wheels, running 700r4, with full posi Eaton 12 bolt diff.....never see above 185 on the temp gauge. Save yourself power drain and install a electric fan from a 98 Lincoln Mark 8.
02-16-2013, 10:46 PM | #9 |
I have a 4-row radiator from Pro Performance and it is cooling my 402 wonderfully. I bought it from him with two electric fans. I have one coming on with ignition and the other is switched in the cab.
The radiator works so well I have not needed yet to turn on the second fan. Temp stays right on 190 |
02-16-2013, 11:28 PM | #10 |
I recently got one from Autozone. The core is aluminum and the tanks are plastic. I'm not sure if this is the route you are going for, but it's an option.
4 core, trans cooler built in, $185. I don't know what temp it keeps my 307, I have idiot lights, but they don't come on. Part Number is A369.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
02-17-2013, 12:02 AM | #11 |
I have an Entropy radiator with two 16" electric fans. It's only a two row core but it has 1.25" tubes. Kinda' pricey though. 14" fans in the picture. The 16" fans were an upgrade.
10-27-2015, 12:27 PM | #12 |
I have found that they all use the 4-row mounts, but confirming just to make sure that is still the case.
Tags |
70 chevy, radiator |
