![]() ![]() Any help appreciated. ![]()
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
#2 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: alternator field bypass test
If so you can jump between the large red wire on the alternator to the "F" terminal on the alternator which should be the white wire. If you have a voltmeter you can check for full output from the alternator large post and the alternator housing. Make sure that the small blue wire that goes into the plug has 12 volts or the alternator field will not energize. Also make sure that the regulator is grounded well to the radiator support and to the alternator and the alternator is grounded to the engine block. Before you do anything, check for 12 volts on the regulator plug brown wire,with the key switch on and 12 volts on the red wire at the same plug with the key on or off. You know that you can take the alternator to Autozone and they will test it for free. If you decide to get a new alternator then get a newer 12 SI model and we will show you how to wire it.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Thanks.
I ended up replacing the alternator. It sitll wouldn't charge. I spent hours replacing wire and checking connections. I believe it was the red wire terminal at regulator that was the problem. I am replacing that connector end ASAP> the charging circuit is working now after I carefully plugged in the regulator plug and the red wire clipped to the terminal.( it pulls out the back of the plug. Could have been the problem all along. Anyway I am keeping the original alternator in the tool box since I think it still works. Thanks for the help
