Firewall Holes
So I've decided to fill in some of the holes in my swiss cheese firewall. The problem is I don't know which ones to leave. The previous owner had just the bare essentials, no heater or ac. I kind of hate to fill them all just to redrill later, is there any way to identify what to leave alone?
58 Fleetside 71 Cheyenne |
Re: Firewall Holes
Here's some pics of what I have -
Re: Firewall Holes
I have always filled all except the steering column and started fresh
Re: Firewall Holes
i'm with solidaxle, i welded everything closed and cut very few after.
i also shaved the standing seam that joins the firewall to both cowl panels if your using the stock elements plan accordingly, ie; hood hinges, battery tray, heater, wire harness ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Re: Firewall Holes
I did the same as Orge except I kept the battery box and ground behind it and stock throttle opening in the recess. Wanted a clean slate to start with.
![]() Join Date: May 2011
Re: Firewall Holes
I did the same as all of the above! Ogre made me do it! lol and then you have to remove the ridge too! ha! It was a pain, but worth the effort. Mine is not nearly as good, but it looks good for my level of expertise. After having a blank wall of no holes, I hated to drill anywhere on my firewall! dne'
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
Re: Firewall Holes
Thanks for all the replies, I went ahead and dove in. Here's this afternoons progress.
Re: Firewall Holes
Wow, you work fast!! ; )
Re: Firewall Holes
feel them all in but the brake an clutch an the steering column by that way if u need to add a hole u can redrill in a nice hidden spot an your firewall looks so much better
Re: Firewall Holes
Yes, You will be much happier when you paint everything and hide the wires down low
Re: Firewall Holes
My next move is to look at moving the harness down low, I have no idea why it's up high. I'm thinking that I can run most of it between the inner and outer fender walls, anyone have any insight on this?
Re: Firewall Holes
That is exactly where I put mine!!
#13 | |
Re: Firewall Holes
my front harness is in the grey flex conduit next to my heater hoses. my engine harness for the ramjet is huge and exits behind my distributor plus 2 wires you see ![]() when i boxed my frame i stuck a straight piece of 1/2'' pvc in the frame that exits out the back for my rear harness you can see a little white pvc sticking out behind my trans x-member ![]()
Re: Firewall Holes
Hey surf thanks for the pictures on the cab mounts. I have decided to go with ez chassis make life a little more simple hopefully. And glad i ran across this I was debating which holes myself the other night.
Posted via Mobile Device |
#15 |
Re: Firewall Holes
No problem, hope it helped.
#16 |
![]() ![]() Join Date: Nov 2008
Re: Firewall Holes
Hopefully I won't get flamed all to hell! lol.
Has anyone tried one of THESE firewall covers? http://www.nolimitparts.com/prodinfo.asp?number=CFWC It's a little pricey but for someone who dosn't know how to weld, maybe it's a consideration? I knew a guy that made his own from sheet metal and it looks fine. Since you cover the interior with sound deadner and carpet (typically) wouldn't this work fine? Do you guys consider it Mickey Mouse? |
#17 |
Re: Firewall Holes
Thanks Ogre! Just curious is there any reason you ran the front harness down the passenger side? I think I have a Painless harness and it was routed on the drivers side for both front and rear. I only have a few wires for the engine so it should be pretty straight forward.
#18 |
Re: Firewall Holes
So everything is welded up and new holes have been cut for the steering column and master cylinder. I'm trying to get ideas on how to run the harness, I like what Ogre did but am wondering what others have done. If I run it low how do I keep it out of sight or protected inside the cab?
#19 | |
Re: Firewall Holes
#20 |
![]() Join Date: Dec 2012
Re: Firewall Holes
What is with all of the holes ?
1971 GMC Sierra 1959 GMC 100 |
#21 |
Re: Firewall Holes
#22 | |
Re: Firewall Holes
![]() Soon my friend, soon
#23 |
Re: Firewall Holes
And often with little thought.
#24 |
Re: Firewall Holes
#25 |
Re: Firewall Holes
ouch that hurts to think about it
