Old 02-18-2013, 11:34 PM   #1
414banger
414banger's Avatar
picture request please
has anyone done a 5.5 front and 5 in rear drop i just did a 5 in drop on the rear of my 65 longbed but it almost looks to low for 5inches but o do have a tranny plus spindles plus springs setting on tailgate and only the passenger side done
here is a picture of it and tell me if im worrying for no reason my main concern is getting the tires on and off of it
414banger is offline   Reply With Quote
Old 02-19-2013, 01:05 AM   #2
414banger
414banger's Avatar
Re: picture request please
anybody ?
Old 02-19-2013, 09:26 AM   #3
414banger
414banger's Avatar
hello is this thing on ?
Old 02-19-2013, 09:49 AM   #4
bonehead
bonehead's Avatar
I had a 61 c-10 years ago that was lowered with 6 inch drop springs in the back. To change the tires I had to carry a bumper jack. That would raise the rear enough to remove and replace the tire if needed on the road.
should work ok. Just look for one that will work with your bumper shape.
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 02-19-2013, 10:01 AM   #5
414banger
414banger's Avatar
thanks bonehead i think once i get everything out of bed and it lowered on all four cornes it will be fine but i do have a pretty wide tire on back plus trac bar needs adjusted too
Old 02-19-2013, 10:19 AM   #6
bonehead
bonehead's Avatar
You might be ok depending on some factors: wheel width, rear end width, etc.
My old truck had a 12 bolt for an 84 suburban swapped in, which is about .75 inches wider per side than stock, if my memory serves... I could unbolt the wheel on mine but could not clear the drum without raising the body with the bumper jack. And I was only running stock 84 chevy c-10 wheels, 5.5 or 6 inch wide max. You'll just have to try it out when you get to that point.
past trucks:
Old 02-19-2013, 12:21 PM   #7
luvbowties
luvbowties's Avatar
Cool Re: picture request please
Keep in mind just what bonehead said: wheel width and rear end width and did I mention wheel width? You may find that you need to run wheels with dimensions like some of the Chevy van rally wheels--some of them came in like 6-inch or 6.5 inch width with practically NO depth, just enough to attach quite narrow chrome bands; even the 7- and 8-inchers often are problems w/out the likes of a bumper jack. (Use a frame jack to remove lugs; use a 2nd jack that can serve as a body-prop while removing the frame jack: might get the wheel/tire out, and save your pretty bumper?)
I've seen our trucks with those narrow rallies on the rear and wider ones on the front--talk about weird--but non-motor-guys might not notice?
Luck to you, and here's hoping space-saver spares can be avoided!
sam
luvbowties is offline   Reply With Quote
Old 02-19-2013, 11:30 AM   #8
BIGCHEATER
sorry lost focus with that Dirt Late setting in the foreground
BIGCHEATER is offline   Reply With Quote
Old 02-19-2013, 01:13 PM   #9
slepysal
slepysal's Avatar
once you do the other side it will be fine
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-19-2013, 03:06 PM   #10
414banger
414banger's Avatar
yea the late model is my buddies it is his garage im borrowing lol im thinking about buying it to get back into racing again on a side not i just got the drivers side done and let it down and damn now my drivers side tire is in the fender lol just have to order a new track rod now also it is setting on the bump stop now does that sound right with a 5 in drop
Old 02-19-2013, 05:25 PM   #11
forestb
forestb's Avatar
That looks like the perfect height to me if the stuff in your bed is making it lower I would remove the stuff and lower the truck to make it the height that it is a now. My step side has a 5 inch drop and my tires are 275R/60R17s. You don't need to put the jack under the bumper just put it under the frame on the side that you want to remove the tire. I think that will give you more room.
forestb is offline   Reply With Quote
Old 02-19-2013, 10:32 PM   #12
LVPhotos
LVPhotos's Avatar
Yep. Jack frame in front of tire. Or I cheat and air rear bags up. I got a low profile Jack from Harbor. Freight. With race car around there has to be a lower, lighter version.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-20-2013, 02:54 AM   #13
414banger
414banger's Avatar
thanks for all the input guys i guess i just wasnt expecting a 5 in drop to be so low lol now the front is setting an inch higher according to the body line so im going to just cut a half a coil off of my new 3 inch drop springs and let er ride
Old 02-20-2013, 03:09 AM   #14
414banger
414banger's Avatar
also a another quick question before i head off to dreamland i have been reading about track bar and all i have read says the rearend moves to the passenger side when lowered well mine is shifted to the drivers side the tire is rubbing the outer fender on the drivers side and the passenger side is rubbing on the inner fender i have an adjustable track bar coming just being curious i guess
Old 02-20-2013, 12:56 PM   #15
forestb
forestb's Avatar
Just do what you need to do to center the tires.
Old 02-21-2013, 03:46 PM   #16
414banger
414banger's Avatar
ok i got the rear lowering done and did one into a problem besides none of the bolt wanted to move i ordered a trac rod from jegs for a 65 c10 i went to put it on today it was 4 inches to short so i called them and they got ahold of mcgaughny and they said i have a 64 rearend in a 65 truck and they was 4 inches longer in 64 so needless to say i just cut and welded to make it work and they gave me a $15 gift certificate for my hassle also the tires come off alright by jacking up on the frame i will post some pics in a couple weeks when i can get it out of garage i still have to cut a half a coil off of my 3 in lowering coils to even ot out all around
Old 02-26-2013, 10:01 AM   #17
414banger
414banger's Avatar
well here is how she sits now i am satisfied with the stance but i am going to have to go with a drop spindle because i used the 3 in springs and cut a half coil off can u say no travel at all lol
Old 02-26-2013, 10:05 AM   #18
bonehead
bonehead's Avatar
That stance looks good to me, wouldn't change a thing if it were mine.
)Bone(
past trucks:
Old 02-26-2013, 10:12 AM   #19
Indian113
Indian113's Avatar
I really like the stance,looking GOOD!
Indian113 is offline   Reply With Quote
Old 02-26-2013, 10:24 AM   #20
414banger
414banger's Avatar
thanks guys im going to keep the same stance just gotta do drop spindles and 2 in drop springs to get a little more trave on the front so i dont knock my feelings out every time i hit a bump lol
Old 02-27-2013, 01:03 AM   #21
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
fwiw, going with a lowering shock helps with this...sometimes on a 5inch drop you'll be running the shocks mostly compressed, making them less effective (handling suffers) and less comfortable.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-27-2013, 03:08 AM   #22
414banger
414banger's Avatar
yea i have lowering shocks all the way around but the springs i was talking about was the front ones i basically have 4 inch lowering shocks which has no travel at all
and yes i HAVE to run disc brake with drop spindles
Old 02-26-2013, 11:23 AM   #23
Indian113
Indian113's Avatar
When you do the drop spindles are you going to add disc brakes?
