53 panel diesel project
Hey I'm planning to put a diesel in my 53. I don't want to modify the firewall too much, but I will if I have to. I haven't decided which diesel to put in. I could use some advice. I'm not trying to make it a hot rod or anything I want to make a solid daily driver that can tow and do anything I need it to while getting good mileage. I want to put a 5 speed behind it and good gears in the rear end. Other than that and an updated suspension, I want to keep it origional. Any advice?
Posted via Mobile Device |
Re: 53 panel diesel project
Not knowing the size of the engine compartment for sure, but I'm thinking they're a little smaller than some of the later trucks.
So I'm thinking a 6bt (cummins 5.9L) would be a tough fit. However a 4bt would probably fit, would give you good mileage, and hopped up a little would do fine towing "regular" loads |
Yeah I wanted to put a 4bt in originally, but I'm concerned about the vibration I keep hearing about. I don't want to invest in an engine that is miserable to drive. Is there any way to manage that?
#4 | |
![]() Here is the only under the hood shot i have... ![]() |
P-pump 24V don't rattle that bad, especially when the injectors and timing are set properly.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK" ASSEMBLY THREAD |
Kick me for not having any good pictures of the engine bay but here are some pictures of a buddys 55 pickup with a 6bt. No firewall modifications but it was tighter than my 68 c10. I had a radiator from a 96 Olds Beretta I found in my barn and used it on the 55. He is currently not running an innercooler and im not sure where to fit one when he decides too. For the mean time i fab'd up a intake tube from the turbo.
Hey schwank. Check my build . The cummins is deffinately a long eng . 4 bt is a cool eng for sure but they are so expensive and hard to find. You should look into one of those militairy 6.2's. I dont know much abt them but it seems they will fit anywhere a sbc will fit. Check Luthers Napco clone 56 build . He is going to put a 6.2 V8 oil burner in his 65 Malibu. He has some comments in his build .
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
6>8 Plugless........
![]() Join Date: Sep 2007
A mercedes diesel or a VW diesel are good options too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
What about an Isuzu, like thay use in the box trucks ? I don't know much about them, but here is one in an early suburban.
http://www.autotraderclassics.com/cl...ationId=555498 |
Thats a 4 bt cummins not a Isuzu. Looks like a nice swap tho !
I'll be nice this time.
Just imagine if it was detroit green ! Then what! LoL. Was still nice looken conversion tho . A/c and all the goodies.
#14 | |
#15 |
Umm, my bad boy's and girls. I read an article on this suburban years ago and was thinking the article said that it had Isuzu diesel. So when I saw it for sale I didn't read what it had or even look at the engine that close. The big blue 'C' on the topside of the motor should have been a good hint as to what brand of engine was in it.
![]() But still what if we break up my original sentence. What about Isuzu diesel's ? In post #9 is an early suburban with a diesel (Not Isuzu) conversion. ![]() |
#16 |
I put a 4bt in a 1970 chevy 4x4 , it doesn't vibrate very much. Lots of torque
#17 | |
![]() Posted via Mobile Device |
#18 |
I like the idea of the 4bt. Good fuel economy, power and I wouldn't have to mess with my firewall, but they are SO expensive! I've found some for around $1500, but I'm still looking. And I need a standard trans for it too. Any ideas where to find some reasonable engines?
#19 |
Look for an older GM bread truck. some have the same bellhousing as the gass engines that used TH 400s.
#20 |
Schwank, any progress or luck finding you an engine? I've got a 1950 GMC 450 firetruck looking to do the same repower. Jim
#21 |
Any luck finding an engine?
#22 |
Still looking for your engine?
