Old 02-21-2013, 03:34 AM   #1
smoknbarrels
Registered Mail
smoknbarrels's Avatar
want to delete my antenna... anyone make a hidden one?
I want to get rid of the unsightly antenna from the wiper/heater panel. But I still want to listen to the raido stations, anyone know of a way to still get radio, maybe with a hidden antenna or some sort of fix?
thanks.
smoknbarrels is offline   Reply With Quote
Old 02-21-2013, 09:21 AM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: want to delete my antenna... anyone make a hidden one?
I bought one earlier this week but haven't received it yet
http://www.classicparts.com/mobile/1.../#.USYfMid5nTo
WIDESIDE72 is offline   Reply With Quote
Old 02-21-2013, 09:41 AM   #3
Gumby
Gumby's Avatar
Get a Pioneer deck with supertuner, don't even need an antenna, got two cars that way, both I just pushed the nub down into the body then welded and smoothed it away. Picks up everything just fine.
One reason I have always stuck with them, that system they invented long ago pulls in stations.
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 02-21-2013, 09:43 AM   #4
cffisher
cffisher's Avatar
years ago I mounted the antennas under the trucks bed worked fine
cffisher is offline   Reply With Quote
Old 02-21-2013, 10:38 AM   #5
68gmsee
Active Member
68gmsee's Avatar
About 5 years ago I installed a windshield antenna on rear window of my 68. I only have AM and it worked good in town but not so good out of the city. I reverted back to the original style since I did a lot of driving in the country.
I still have it mounted on the rear window. I fed the antenna/power cable up through the cab light fixture and out the bottom of passenger side rear corner. From there I ran it through the channel and to the radio.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 02-21-2013, 10:31 AM   #6
JOJABOY
I've had several friends with universal whip antennas frame mounted under cab. I currently have a universal whip mounted under my dash. The base is under the gove box and it points toward the steering column. I pick up both L.A. and San Diego stations just fine.
JOJABOY is offline   Reply With Quote
Old 02-21-2013, 12:45 PM   #7
smoknbarrels
Registered Mail
this sounds like an easy fix, I'll try one of these perhaps, if it works well.
Thanks!
Old 02-21-2013, 12:55 PM   #8
ls1nova71
ls1nova71's Avatar
I tried all kinds of ways to hide the antenna on my '33 Ford, tried one under the dash, one above the windshiedl header panel, and even one of those Dakota Digital ones that glue to the windshield, and they all were less than desierable. I now have a regular antenna on the back, works perfect. The moral of the story, if you really want the radio to work as well as it should, leave the antenna on it. Just my $0.02
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-21-2013, 11:10 AM   #9
Sammy
If you find one short enough just lay it with some tie wraps above the radio under the dash area.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-21-2013, 12:03 PM   #10
Lemield
Lemield's Avatar
thanks.
I have used a Tunetrapper antenna with great success. Found mine on Ebay.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
