02-21-2013, 02:23 PM | #1 |
Pro's and Con's of slamming your Truck
Pro's ,easier to get in,con's ?
02-21-2013, 03:00 PM | #2 |
At the body shop.
Re: Pro's and Con's of slamming your Truck
Depends... on your opinion of coins.
" That didnt make it any newer " " Dont antique the equipment " |
02-21-2013, 03:13 PM | #3 |
Con....I have 7 miles of gravel roads before I see any sort of pavement. Would never work for me,besides I like to have to jump,crawl up into my truck!!
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
02-21-2013, 03:36 PM | #4 |
Cause it looks cool
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
02-21-2013, 03:50 PM | #5 |
Slots go on anything!
Pro: looks better, rides better, is better.
Con: none that I can think of. This is all just opinion, of course. |
02-21-2013, 06:04 PM | #6 |
Slammed to the ground, means stranded one day
Posted via Mobile Device |
02-21-2013, 08:12 PM | #7 |
Driving any truck (machine) raised, lowered, or stock height can leave you stranded one day.
02-22-2013, 12:41 PM | #8 | |
02-22-2013, 12:55 PM | #9 | |
Any machine can leave you stranded which is what you commented on. I wouldn't build anything to lay frame; even a weekend warrior.
02-22-2013, 01:04 PM | #10 | |
02-21-2013, 06:36 PM | #11 |
Pro's really depend on who you are, and what you like to do. But for me better handling, easier to work on the engine, and I just prefer it myself for no reason I really can tell you.
Cons can be pretty wide to none depending how you defined the term slamming your truck. For the sake of argument with a frame height of 5" there are almost no cons that would not be there in a normal car. If you go down to 4" you begin to run into troubles with speed bumps, dips, and entering steepish driveways. 3 or less inches, and your screwed 6 ways to Sunday. Plus twice on Sunday. Its a enthusiast setting, and depending on how much you drive it can get old really quick. Plus there is what truck you have. The above pretty much is true for rcsb's, and rclb's. Though rcsb will be alittle easier, but not enough to write home. Now if you go big like in your pic a cclb. Which I never owned yet, but only have driven a slightly lowered one. Problems where it is practically un-driveable as far as entering parking lots can come in as early as a 5" frame height. In the end it is your vehicle, and if your can tolerate it. Yes you too can ride that low. |
02-21-2013, 08:54 PM | #12 |
Its just plain cool
Scott 82 step side aka " Bouncy " 73 GMC Long bed Vortec 5.7 |
02-21-2013, 09:42 PM | #13 |
Square
pros, looks
cons, people complaining that you ruined a perfectly good truck.
Squarebody Syndicate |
02-21-2013, 09:49 PM | #14 |
Cons - It takes way more work to get them on the ground!
Trust me I have built them both ways and a jacked up 4x4 on 40's is so much easier.
1949 Five Window, 1973 Step Side, 2000 Z71 |
02-21-2013, 09:50 PM | #15 |
PRO: Lower Roll center and handling better. If done correctly better steering. CONN: Dirt roads and speed bumps. Having to change driving habits when turning into parking lots that are elevated.
NAME: TRAVIS TRUCK: BRUISER 71 C/10 SWB 3.5/5" drop 4.11 GEARS. F.A.S.T. BBC 408 496hp/479ft/lb JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530 |
02-22-2013, 03:10 AM | #16 |
pros: it's because we like it.. your truck you decide what you like. cons: they sometimes drag the ground and cost $ to do.. Lifted/lowered it's all good. good luck either way.
02-22-2013, 09:33 AM | #17 |
I have had several extremely low vehicles both static and bagged. I do it because I like it but there are always some headaches that go along with it, especially if youre static. I had a Subaru WRX with 1.5" clearance from the from bumper. It got to be so annoying to drive that I almost never drove it. Like the earlier post said stick with at least a 5" ride height and you should be good.
NEED TO BUY STREET TRUCKS ISSUES 1/08 5/09 1/12 PM ME IF YOU HAVE THEM 1978 C10 SWB bagged - PB Dropmember/ Kp cantilever 4-link 2017 Silverado CCSB LTZ Z71 Midnight edition 1950 Chevy 3100 5 window - all original |
02-22-2013, 01:12 PM | #18 |
im raising mine back up because i got tired of it, not being able to get under the truck, tires rubbing the wheel wells, not being able to drive on work sites for fear of getting hung up etc. i had a vw karmann ghia once and i hammered it, well right before i sold it i raised it back up some, i wish i wouldnt have lowered it, driving it beat the living hell out of that car!
02-22-2013, 01:13 PM | #19 |
Moderator
Lowering trucks is one of those things...if you have to ask...well there is no answer! It's all about the looks, and if you're really into it like most of us the ride can be an added benefit. I do get tired of the "you ruined it" comments but they're usually not mean spirited, just tells me they aren't hot rodders or truck guys.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
02-22-2013, 01:16 PM | #20 |
im a hot rodder and a truck guy, i dont like them lowered, does that mean im less of one than you?
02-22-2013, 01:57 PM | #21 |
02-22-2013, 03:18 PM | #22 |
02-22-2013, 03:38 PM | #23 | |
Moderator
I'm sorry I veered off topic. Personally, I like my daily drivers static dropped low enough to look good and not too low that I can't get into my driveway or make a run to the dump...which is exactly why people use air bags, best of both.
02-22-2013, 04:56 PM | #24 | |
02-22-2013, 01:40 PM | #25 |
Happy to be here
Pro's- If done correctly it will improve your ride and vastly better SPG (smiles per gallon).
Con's- Listening to uniformed people say how poorly it rides, how badly it beats the truck up, and it is no longer functional as a truck......BS
