Old 02-21-2013, 08:48 PM   #1
gdavis
gdavis's Avatar
parts
rolling chassis LWB 6 lug 1972 frame with 1968 rear end and 1968 front suspension the rear end has new seals both sides. The front suspension has new ball joints installed. I was going to use but I went and bought a 1972 frame with disk brakes and 5 lug rear. That is why it rears 1972 6 lug. Frame is in good shape. There is a small bend on the frame on the nose about 10 inch fron the front
1972 3 speed granny transmission standard 75.00
1972 stell beel housing 75.00
1972 fly wheel 50.00
1967 poss traction rear end. 3.73 ratio 200.00 sold
rolling chassis without tires and wheels LWB 500.00
1967 small window cab rain gutter is
in bad shape on the pass side.The inside
is in great shape. Needs cab cornors on L/R side.
needs rockers. The floor is in good shape. 100.00
will send pictures if interested.
1971 -1972 front and rear bumper chrome. 50.00 each
gdavis is offline   Reply With Quote
Old 02-21-2013, 08:53 PM   #2
gdavis
gdavis's Avatar
Re: parts
Also a tail gate for a 1968 step side 100.00
Old 02-22-2013, 01:11 PM   #3
greentruck
greentruck's Avatar
Re: parts
What is the gear ratio of the rear end? Thanks
greentruck is offline   Reply With Quote
Old 02-22-2013, 08:22 PM   #4
gdavis
gdavis's Avatar
Re: parts
I dn't know at this moment. I will find out Tuesday and let you know.
Old 02-23-2013, 05:57 PM   #5
greentruck
greentruck's Avatar
Re: parts
Ok great. It's the posi rear end I'm interested not the rolling chassis. Thanks.
Old 02-23-2013, 07:08 PM   #6
gdavis
gdavis's Avatar
Re: parts
The only way, I can tell what ratio the rear is to spin the tire. I made a mark on the tire and the yoke on the front of the rear end. The ratio is 3.75 to 1. If there is another way let me know.
Old 02-23-2013, 07:11 PM   #7
gdavis
gdavis's Avatar
Re: parts
The tire size on the rear end is P225x75R15. That is the size of tire I took the marks for the ratio of the pos rear end.
Old 03-01-2013, 09:27 AM   #8
FL71C10
Re: parts
What kind of shape is the tailgate in? Any pics?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 03-02-2013, 05:29 PM   #9
gdavis
gdavis's Avatar
Re: parts
needs some sand blasting and a little bondo
Old 02-22-2013, 01:21 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Re: parts
Is the frame SWB or LWB?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-23-2013, 07:12 PM   #11
gdavis
gdavis's Avatar
Re: parts
Originally Posted by leddzepp View Post
is the frame swb or lwb?
lwb 1972
Old 02-23-2013, 07:26 PM   #12
greentruck
greentruck's Avatar
Re: parts
It sounds like you have a 3.73 ratio. Another way to tell for sure is to remove the differential cover and read the stamp on the ring gear. For a ratio of 3.73 it would read 41/11. I've got 3.07 gears up front so it wouldnt work for me. Thanks for checking!
Old 02-25-2013, 07:53 PM   #13
gdavis
gdavis's Avatar
Re: parts
Does anyone have a set of 350 chev exhaust manifold. I will be willing to swap some of my parts for. Or buy out right.
Old 02-25-2013, 11:05 PM   #14
Bpokey
Bpokey's Avatar
Re: parts
If possible could I get pictures of the cab? Thanks
Bpokey is offline   Reply With Quote
Old 02-26-2013, 09:32 PM   #15
gdavis
gdavis's Avatar
Re: parts
here is the pic of the cab. The inside of the cab is in perfect shape. Around the wind shield is spotless. No rust at all. The floor is in good shape. The only damage is exterior.
Old 02-26-2013, 09:34 PM   #16
gdavis
gdavis's Avatar
Re: parts
IfGdavis Homosassa, Florida u want to see more tell me what you want to look at and I will send them.
Old 03-01-2013, 12:32 AM   #17
Bpokey
Bpokey's Avatar
Re: parts
The only other areas I worry about is the firewall and below the dash on the inside. My cab had rusted so bad the windshield wiper motor broke loose. There is also under the dash where the seams meet on either side. Thank you for the information. Brian
Old 03-01-2013, 07:51 AM   #18
Leroy-B1
Re: parts
Interested in the rear end how long can it be held until pick up if paid for
Leroy-B1 is offline   Reply With Quote
Old 03-02-2013, 05:36 PM   #19
gdavis
gdavis's Avatar
Re: parts
as long as you like. which rear end r u talking about I have two.
3.73 pos traction 200.00 sold
regular rear end 150.00 stock
Old 03-01-2013, 09:30 AM   #20
FL71C10
Re: parts
Is the rear bumper for a fleetside or stepside?
Old 03-02-2013, 05:33 PM   #21
gdavis
gdavis's Avatar
Re: parts
pictures of the bumpers
Old 03-01-2013, 01:58 PM   #22
72mistressc10
72mistressc10's Avatar
Re: parts
Interested in front bumper, driver quality, pics?
1972 C10 LWB Cheyenne Super
God Said,"Owning A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
........................__
..........._______ |__\__
..........|__(O)______(O)]
72mistressc10 is offline   Reply With Quote
Old 03-02-2013, 05:31 PM   #23
gdavis
gdavis's Avatar
Re: parts
front and rear bumper together or will sell seperate.
Old 03-02-2013, 05:39 PM   #24
gdavis
gdavis's Avatar
Re: parts
does anyone have a good set of exhaust manifold's for a 1970's 350
Old 03-03-2013, 03:10 AM   #25
Bpokey
Bpokey's Avatar
Re: parts
I think I will pass on the cab, Thanks for the pics. I may have a set of exhaust manifolds on a parts truck I have in Missouri, I don't remember what shape they were in. I am planning a trip there late next month and I can check on them then.
