Old 02-25-2013, 06:36 PM   #1
jmorri34
jmorri34's Avatar
Cowl hoods
I was wondering if there was any good or bad opinions on the steel cowl hoods that are out there as far as fit wise. Is the fit on them good or bad and is there only one size cowl hood out there, only one i see is a 2 inch i believe. I am thinking of putting one on my 69 fleetside prostreet I am building.Thanks in advance for any feedback.
jmorri34 is offline   Reply With Quote
Old 02-25-2013, 06:54 PM   #2
54belair
54belair's Avatar
Re: Cowl hoods
Very seldom is the fit perfect! But, with some time and effort in making adjustments you can get them pretty close.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 02-25-2013, 07:05 PM   #3
haysonj
haysonj's Avatar
Re: Cowl hoods
I bought mine from LMC and it fit fairly good. The gaps arn't perfect but are close. I didn't care for the foam they use in place of the stock felt.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 02-25-2013, 07:23 PM   #4
Fldawg
Fldawg's Avatar
Re: Cowl hoods
here's mine , gaps good but was a pain in the a$$ to get there
Fldawg is offline   Reply With Quote
Old 02-25-2013, 09:50 PM   #5
jmorri34
jmorri34's Avatar
Re: Cowl hoods
Thanks for all the help guys, one other question if I may, what kinda work is involved with it, is it cutting and welding type work or metal bending and working type stuff. once again thanks for everything!!
Old 02-25-2013, 10:06 PM   #6
54belair
54belair's Avatar
Re: Cowl hoods
Most of the work involved will be working with everything in the front clip. Loosening, moving, adjusting, tightening, inspection-----then start over.
There are different mfger's some of them ae better than others. If its real bad, you may not get it really close.
Mine was close and I think I could have gotten it closer (?) but I decided to go old school and back to stock.
1968 short stepside
1966 mustang
1966 chevelle ss
My Build Thread
Old 02-25-2013, 10:18 PM   #7
jmorri34
jmorri34's Avatar
Re: Cowl hoods
Ok thanks a ton, I was debating whether or not to do itbut not sure if I will or not, maybe when I get ready to paint and all the stuff comes off .
Old 02-26-2013, 10:00 AM   #8
54belair
54belair's Avatar
Re: Cowl hoods
Be sure to fit it before you paint , it might take some time and several tries to wiggle, adjust----maybe even "massage" the fit.
1968 short stepside
1966 mustang
1966 chevelle ss
My Build Thread
Old 02-26-2013, 10:15 AM   #9
BrutonLS1
BrutonLS1's Avatar
Re: Cowl hoods
Not to hijack the thread, but I think it relates!
How much "massaging" do the LMC truck doors need? Are they even worth buying?
-Bruton
1968 GMC long bed 5.7/700R4
--I'd rather push a Chevy, than drive a Ford.--
BrutonLS1 is offline   Reply With Quote
Old 02-26-2013, 10:55 AM   #10
Shyguy
Junior Member
Shyguy's Avatar
Re: Cowl hoods
I got the 2 inch cowl hood for my '67 from LMC. If I had it to do over I think I would call some vendors and see how their cowl hoods fit and the quality.
We did manage to get the cowl hood to fit ok, but not perfect, but had to do some shimming on the fenders and grill to get it to be ok.
I have seen two cowl hood heights, a 2 inch and a 4 inch.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 02-26-2013, 03:47 PM   #11
jmorri34
jmorri34's Avatar
Re: Cowl hoods
Im beginning to think I should stay with the stock hood lol!!
Old 02-26-2013, 04:01 PM   #12
LEllyson
Re: Cowl hoods
I have a goodmark 2 inch cowl on my 88 1ton and it fits the best i have seen but looking closely it still is not perfect. For some reason the aftermarket just never seems to fit as good as original from hoods to doors to even weld in parts like rockers and cab corners. My 71 is in the middle of getting rocker, floor pans, cab corners and all the typical things that usually rust out on these pickups and none of them have been a perfect fit.
1988 Chevy 1-ton 502/gear vendor overdrive
1971 shortwide 350/350
1991 Jeep wrangler 350/400 atlas II 1-tons
LEllyson is offline   Reply With Quote
Old 02-26-2013, 04:08 PM   #13
hilljob26
hilljob26's Avatar
Re: Cowl hoods
i made my own cowl hood with 2 stock hoods,,nothing fits better then stock
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 02-26-2013, 05:15 PM   #14
Tim Christian
Tim Christian's Avatar
Re: Cowl hoods
Actually when these trucks were new they was not a good line on them! JS!
Tim Christian is offline   Reply With Quote
Old 02-26-2013, 05:39 PM   #15
jmorri34
jmorri34's Avatar
Thumbs up Re: Cowl hoods
Thats pretty darn nice for a home made cowl hood. Looks sharp!!
