02-26-2013, 12:08 AM | #1 |
3-2 setup
I have a 3-2 carb setup for sale. It fits small block Chevy engines up to 86. It has a new Edelbrock manifold. I rebuilt & detailed 3 Rochester 2G carbs. with Eastwood Bronze paint. The center one has a manual choke. I used Speedway shaft & throttle blade kits. I used Offenhouser progressive linkage kit. $1000.
georgec2434@yahoo.com |
02-26-2013, 10:14 AM | #2 |
Re: 3-2 setup
Can this model of carb. be set up with an electric choke?
Have you tried them since rebuild, Is linkage progressive or both end units together?
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
02-26-2013, 12:36 PM | #3 | |
Re: 3-2 setup
The progressive linkage opens the end carbs together at about 2/3 opening of the center carb. I have never run it. George |
02-26-2013, 04:08 PM | #4 |
Re: 3-2 setup
Thanks for your answer George, After I asked the questions, I did some research and I believe Id need a 2gc or 2 gv (has the choke assy).
Id like to run three deuces--realized I didnt know enough about them.
